High packet loss and other DNS issues
AvengerUK01
Re: High packet loss and other DNS issues
I've had major issues last night / this morning - it was unusable.
No graph to share yet, as I've turned it all off for the day while I'm at work...
Hope it isn't back to how it was again.
Bob1
@yyurchuk05 wrote:
Anyone else seeing this?
Yes, it looks like packet loss is back from about 8am this morning.
9.20am Fri
My Broadband Ping - Bob1 (Static IP 55/10)
I haven't seen this for a while. The only problem I have been getting regularly is that the connection drops for about a minute, sometimes the yellow excamation mark comes up on the taskbar, sometimes not.
AvengerUK01
Oh great.
That's exactly what I was seeing Bob. It would drop out every minute or so.
ricom831
My Broadband Ping - Home PlusNet
jtjacques
I'm also seeing the same. Packet loss since 8:00 and frequent drops of connectivity. I've added a live TBB graph as well.
My Broadband Ping - Plusnet Static
Fru
415d9fd2a359064f6b76826ae81c8824-07-10-2016
Just adding to the reports, same here since 8AM
AvengerUK01
Just for everyone else -
Had a quick chat with Plusnet support again with an extremely friendly & chatty agent - has now seen this thread and your graphs, and also spoken to the "fault contact" while I was chatting to raise it - although they apparently said "its fixed and to do the normal checks"
Also has given me a new static IP to see if that would help - (I already had one from the previous issues) - sadly I can't test this until I get home Sad
Will report back.... hopefully it'll be fixed.
btsimonh
Not read the whole thread, but woke up this morning to my fttc connection lasting between 30s and 1:30s before dropping, then reconnecting.  I power cycled everything, re-checked, it was the same.  Called plusnet, and they told me this was a classic symptom of the router failing (not the modem..) (I have an openreach + a BTHHV2A OpenWRT).  So I replace the BTHHV2 with the original Sagem, and the issue was still there.
I then replaced the power supply of the OpenReach modem with the Sagem supply, and my connection has been up for 28 minutes now (back on original router and cabling)...
coincidence, or @AvengerUK01 's conversation had them fix something?
Either way, let's hope it's fixed :).
ricom831
Thanks AvengerUK01
I'm seeing noticeable better performance now and graphs no longer showing packet loss. Things are good again!
AvengerUK01
Great news hopefully Smiley
(And no problem, I'd rather talk to Plusnet than do Risk management this morning!!!!!)
Fru
I think you did the trick @AvengerUK01, I rebooted both my modem and router and now all seems to be back to normal.
Thanks! Smiley
bobpullen
Fixes: 316
Morning guys,
The routing/packet loss issues this morning was due to a flapping route. It will mainly have affected customers who have been migrated to new network and are assigned a static IP.
An incident was raised (ref: 95003) and the problem mitigated around 9.50am. Our engineers are looking into what caused it but it's unrelated to the issues being discussed previously in this thread.
Sorry to those of you affected.
St3
Aspiring Champion
Fixes: 5
Yes it affected me too, welcome back to the forums bob Knuppel Cheesy
rongtw
Fixes: 12
Ste ,,, So you got a flapping route. Cheesy
scottrc
I think someone added a static IP to my account when all this was happening. Do I still need it? if not, could someone please remove it. Thanks
