Has anyone's speed decreased recently?
OriginalTM
Hi everyone,
Sorry to bother but I was wondering if anyone else is having the same issue as me at the moment as I'm currently on Plusnets 70/20 plan and was quite happy as my speeds were around 49/14. However recently since going on holiday the speeds have tanked to around 20/12 (Uploads still quite good however the download is less than half of it's previous average).
It's not major and I understand that their may be line maintenance and optimizations going on however it just strikes me as odd that it was fine until the past couple of weeks.
Is anyone else experiencing these issues and is it worth me giving CS a quick call just to check whats going on?
17 REPLIES 17
SteveA
Re: Has anyone's speed decreased recently?
Is it a drop in sync speed or a drop in speed on downloads (i.e. a speed test)
pjmarsh
Fixes: 20
Hi
It would be pretty unlikely that it would effect many others on the forum (at least without a major event happening, then the forum would be inundated with people reporting it).  Most likely it is something to do with your connection, either internal to your property, or externally.  Next possibly, which is less likely is that it is a problem with your cabinet or exchange which would only affect people in your area.
We first need to pin down what is being affected, which is were SteveA's question comes in.  If it is a drop in sync speed (the speed that your router connects to the cabinet), then that points to issues with your physical line or equipment, or some kind of interference (internally or externally to your premises).
If it is a drop in your throughput (as seen on a speed test), but your sync speed hasn't dropped, then there are another set of potential issues to solve (such as wifi performance).
Phil
SteveA
But be aware that a sudden drops in sync speed may well be dismissed if the line is running within its defined range (I recently got a 13% drop in sync speed and PN said that as the line was still within its sync range it wasn't a problem).
Chris
Legend
Fixes: 169
Thanks for getting in touch and apologies for the issues you're having with your speeds.
Checking your estimates your line shows that you should be connecting between 74 and 80Mb/s
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 80 74 20 20 67 Available -- -- -- --
However your line is currently connecting to the cabinet at 25.0 Mbps.
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 25.0 Mbps
Upstream Speed 19.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Radio Frequency Ingress Detected
Cross Talk Not Detected
Estimated Line Length In Metres 554.5
Upstream Rate Assessment Good
Downstream Rate Assessment Low
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-25M Downstream, Retransmission High - 0.128M-19M Upstream, Retransmission Low
Time Stamp 2017-06-16T13:45:00
I'd definitely advise making sure you're connected to the test socket and then report to us as a fault at https://faults.plus.net
OriginalTM
Hi Chris,
Thanks for letting me know as it is certainly not getting those speeds (I wish it were). I'll have a go when I get home today to move the modem as it might be a dodgy cable between the master socket.
I'll let you know if moving the modem works Cheesy
Chris
Legend
Fixes: 169
Let us know how you get on!
OriginalTM
Hi Chris,
I got back home today and to rule out any other variables I plugged my testing BTOR modem into the test socket under the faceplate. I also went directly from the BTOR modem to my laptop and it still looks to be getting ~23Mbps. I think their might be an issue with our cabinet outside so I'm going to check with support and see if they can reset it for us. Smiley
MatthewWheeler
Fixes: 480
Our tests have now found a external fault so we've raised that for you.
As soon as we know more we'll let you know.
 Matthew Wheeler
OriginalTM
Perfect, I'll keep an eye on the phone and the speed to see when it gets sorted. Smiley
OriginalTM
So as an update an engineer came out today and fitted a new cable however the speed only increased by 1Mbit. Despite this the guy on the phone has put the issue forward for more investigation as it might be something on the cabinet end. Smiley
Fixes: 1,601
I've updated this ticket for you. If you let us know once you've replied, I can get the fault moving forward Smiley
OriginalTM
Hi, I've now responded to the ticket Smiley
MatthewWheeler
Fixes: 480
We'll get that picked up shortly.
 Matthew Wheeler
OriginalTM
Superb, just waiting to get a day sorted now (Awesome work so far though) Smiley
