Fibre download speed down from 70Mb to 1.8Mb today =(
- Fibre download speed down from 70Mb to 1.8Mb today...
Re: Fibre download speed down from 70Mb to 1.8Mb today =(
16-09-2017 3:24 PM
Yes agreed, it sounds like a configuration/firmware change (to their kit) has been made which hasn't gone well.
In this case, where multiple people have said the same thing, across the country - it should be rolled back and investigated why it was bad.
In my job I know how it is, nothing is ever perfect. I can also understand the lack of communication frustrates people, but to even admit there is a problem, we don't know what it is yet, we're looking into it would help.
16-09-2017 3:38 PM
fwiw, I haven't noticed any issues with my fibre connection. speedtest.net and BT wholesale speedtester results look fine.
Could it be a gateway problem?
My WAN IP is in the subnet 46.208.65.x
Tracing route to www.bbc.net.uk [212.58.246.95]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms home [192.168.1.254]
2 * * * Request timed out.
3 * * * Request timed out.
4 7 ms 7 ms 7 ms be3-3100.pcn-ir01.plus.net [195.166.143.128]
5 7 ms 8 ms 8 ms 195.99.125.136
6 8 ms 8 ms 8 ms 62.172.103.51
7 9 ms 8 ms 10 ms 195.99.126.73
8 * * * Request timed out.
9 13 ms 13 ms 14 ms ae0.er02.cwwtf.bbc.co.uk [132.185.254.90]
10 14 ms 14 ms 15 ms 132.185.255.165
11 12 ms 12 ms 12 ms bbc-vip016.cwwtf.bbc.co.uk [212.58.246.95]
16-09-2017 3:41 PM
its not our routers, I have tried three routers and two modems and get the same problems.
16-09-2017 3:42 PM
There does appear to be a fairly major problem on the Network currently and is affecting ALL ISp's Here's an example for Plusnet, but check out the other suppliers - a common problem. Still doesn't excuse the lack of communication from Plusnet though.
I'll give a prod to try and get a response. But it is the weekend.
16-09-2017 3:54 PM
@pjblaze wrote:
Same here in South Wales. Usually have a steady speed of 35-40mb and can barely get it above 2 this morning. Got through to customer services after 30 minutes who said there were no issues their side and it would probably be a wifi channel issue, so sent me instructions via email and went. I've tested every channel and they are all exactly the same. Now back on the phone for another 30 minute wait.
Also in South Wales, Ordered with install date of 30th - Cheers. I will cancel. Can't be having this.
16-09-2017 3:56 PM
@Alex wrote:
I just replied on another thread where it seems to be the same issue.
Will try mine later today, but it doesn't seem to be localised.If anyone knows someone on a different ISP to test it'll help, I'm on cable, my parents are on PlusNet.
I am on Talk Talk Business. (main line) Streaming 4K from Plex as I type this - not had a problem for about 4 months.
16-09-2017 3:58 PM
@stereohaven wrote:
@Alex wrote:
Hmm, so it sounds like a dodgy router firmware update has been pushed out maybe.
Not something beyond the router?I'm using a Home Hub 6 because the Hub One is useless. I did a swap for an Asus I had knocking about as well, same speed issue.
Personally I can't see it being a firmware issue at router level, but I do accept I'm not a super techie.
I was going to use the HH6 too.
16-09-2017 4:05 PM - edited 16-09-2017 4:05 PM
looks to be coming back up now nearly there ,,,,,,, Still NOWT from Plusnet ... here , twit or bookface
16-09-2017 4:09 PM
Ridiculous download speed in Grange over Sands Cumbria. Upload fine.
Must be a major failure for the WHOLE country to be affected. Surely BT will have its finest engineers sorting the issue?
Rather than asking useless Plusnet, has anyone actually contacted BT?
16-09-2017 4:16 PM
Hello neighbour! (in Grange too!)
16-09-2017 4:23 PM
Same here in Hampshire. Usually around 19mb, now 1.03. I'm sooooooooo fed up with this service. The bloody router has been cutting out and dropping me at random the last few weeks and now this nonsense. I have to wait till March to escape, too. Not happy.
Lynda~
on 16-09-2017 4:55 PM - last edited on 16-09-2017 5:00 PM by Mav
I was waiting to join, I just called and cancelled. I can't be having that sort of problem. Hope for a price rise soon is all I can say to you!
I have Talk Talk Business too - I might pay £45 a month but it's rock solid. I only wanted a backup. Bit pointless when the backup goes down more than the main!
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
16-09-2017 4:56 PM - edited 16-09-2017 5:10 PM
BT report no problems, No ISP using Talk Talk wholesale has a problem either. This seems to be purely a Plusnet problem.
16-09-2017 5:08 PM
Same problem in Devon.
Connected through be2.pcn-ir01.plus.net
16-09-2017 5:40 PM
Finally an admission of a fault!
