DNS Issues?
- DNS Issues?
Re: DNS Issues?
29-02-2016 10:16 AM
Re: DNS Issues?
29-02-2016 7:37 PM
I put in a request to the Technical Support people (9 days ago!) but they weren't able to help me other than suggesting I reboot my router.
Could you please do for me what you've done for the others?
Thanks in advance.
Cheers, Ian
Re: DNS Issues?
29-02-2016 7:52 PM
I appear to be having the same issue and I'm on windows 10.
Keep losing the primary DNS which is set to plusnets.
Could I be pushed the fix? This has only been occurring since the router firmware upgrade.
Many thanks,
Isitari.
Re: DNS Issues?
01-03-2016 6:14 PM
I've done the Telnet fix. Should I get the fix pushed my router anyway? Bob, can you assist if so?
Cheers,
Roger
Re: DNS Issues?
01-03-2016 7:42 PM
To the preceding two posters, are you still experiencing problems?
Re: DNS Issues?
01-03-2016 7:57 PM
Changes my local machines dns back to google's dns servers seems to again help.
I've just backed up the router configuration and it seems that the fix is still applied.
If you want me to run any specific tests then please let me know.
Re: DNS Issues?
01-03-2016 9:42 PM
Quote from: Bob If you've carried out the telnet instructions Roger, then me pushing the fix won't help any further.
No disconnections tonight so seems to have worked! Thank you.
Re: DNS Issues?
04-03-2016 7:41 PM
a friend has the TG582n router that has displayed the delayed web site loading problem that may be linked to DNS WanSpoofing
Can Bob send the fix to please? will PM you the user name
Re: DNS Issues?
05-03-2016 2:32 PM
Re: DNS Issues?
05-03-2016 3:11 PM
So is there a more general problem with Plusnet's DNS?
Are there known Hub One issues?
Is there any scope of changing DNS settings on Hub One itself?
Re: DNS Issues?
05-03-2016 8:50 PM
Quote from: HighChaparral So is there a more general problem with Plusnet's DNS?
Not that I'm aware of.
Quote from: HighChaparral Are there known Hub One issues?
Again, nothing that would lead to the symptoms you're reporting.
Quote from: HighChaparral Is there any scope of changing DNS settings on Hub One itself?
Not at present I'm afraid.
Quote from: ifrancis @Bob - It seems to be sorted now. Was that your doing? Thanks anyway.
Nope, although I know we're in the middle of pushing the fix out to all upgraded devices. It could be that it's been done as part of that program of work.
I'll check the others when I'm back in the office next week.
Re: DNS Issues?
06-03-2016 11:20 AM
What a relief to find this thread as it explains all of the issues I've been having recently and which have been making me tear my hair out!
Is there any chance you could apply the same fix for me too?
I hope this is ok & many thanks in advance
Mike
Re: DNS Issues?
07-03-2016 11:10 AM
Quote from: gpsmout a friend has the TG582n router that has displayed the delayed web site loading problem that may be linked to DNS WanSpoofing
Done.
Quote from: greswolde Is there any chance you could apply the same fix for me too?
Also done.
Re: DNS Issues?
07-03-2016 11:41 AM
I don't (seem to) have the problem addressed in this thread, probably because I am running Windows 7. However, I do have the Technicolor router with the latest firmware.
I don't want the problem but one day either I will make a mistake with Windows Update and get Windows 10 by accident, or (for likely) buy a new PC with Windows 10 pre-installed. Then I may well discover the problem.
Are you in a position to say what it may be possible for PlusNet to do for those of us who currently don't have the problem but one day may upgrade to it? Other than for me to get a new router (which may, indeed, be good advice)?
Michael
Re: DNS Issues?
07-03-2016 1:59 PM
Thanks for the very quick response - much appreciated. Hopefully this will now have solved the problem.
Regards
Mike
