Slow Speeds
FIXED- Subscribe to RSS Feed
- Slow Speeds
21-07-2017 8:58 AM
Just wondering if there is a problem in my area, just hit some really low speeds this morning, its relatively half of what the download speed should be and normally is.
http://www.speedtest.net/result/6472898708.png
Fixed! Go to the fix.
Re: Slow Speeds
21-07-2017 2:33 PM
Hi @Beermonsta,
Nothing is flagging up during testing, however your sync speed (25Mbps) is definitely lower than I'd expect, given the estimates for your line.
Could you go through our troubleshooting guide here and if you continue to experience problems after this, please report a fault and let us know once you've done this.
Thanks.
Re: Slow Speeds
21-07-2017 5:51 PM
Thanks for the reply Harry,
I have a suspicion to what the problem is, Ive had a fair few disconnections these past few days due to a dodgy electricity supply, It may be that Plusnet or Openreach are limiting my speeds thinking there's a fault somewhere!
Strange that its only just kicked in though, but the speed is slowly on the rise.
Re: Slow Speeds
22-07-2017 11:33 AM
It looks like your line is banded.
Profile Name | 0.128M-25M Downstream, Error Protection Off - 0.128M-2M Upstream, Error Protection Off |
I've sent your account over to my colleagues to request Openreach to reset your line. It should be done on Monday.
Let us know how it goes.
Re: Slow Speeds
22-07-2017 11:43 AM
Re: Slow Speeds
22-07-2017 1:39 PM
Thanks Anoush,
Ill let you all know Monday night if all goes well!
Re: Slow Speeds
22-07-2017 2:16 PM
@Browni wrote:
Can you reset fibre lines now?
It's a trial process.
@Beermonsta wrote:
Thanks Anoush,
Fingers crossed!
Re: Slow Speeds
24-07-2017 6:10 PM
I dont know if Openreach have done or fixed anything, but its worse than it was before, Anoush.....http://www.speedtest.net/result/6481638568.png
Ive been out all day and my cabinet is visible from my property, so I cant tell you if OR has been or not, is there any notes on my account?
Glenn
Re: Slow Speeds
25-07-2017 9:41 AM
Hi Glenn,
It looks like the e-mail we sent over to our suppliers didn't get picked up, because the trial process to remotely reset a fibre line ended on the 21st July. We'll need to progress this the usual way by arranging an engineer visit.
If you've done the usual checks here can you report the fault to us at http://faults.plus.net
Re: Slow Speeds
25-07-2017 9:51 AM
Done, Its becoming a pain in my [-Censored-] now Anoush, no wonder why a number of users are moving away from BT owned internet!
But thanks very much
Glenn
25-07-2017 4:57 PM
Re: Slow Speeds
29-07-2017 10:50 AM
My speed seems to be back to normal now from the speedtest I carried out just now, so Ive closed the ticket.
https://www.thinkbroadband.com/speedtest/1501321675541934055
Glenn
Re: Slow Speeds
29-07-2017 11:59 AM
