Consistantly slow fibre speed
steve57
When we changed from ADSL to fibre our download speed was initially around 30Mbs but over the last few months our speed has dropped to a consistant 13.84Mbs. We have carried out all the steps to check for faults at our end including connecting via ethernet cable but the results are the same. Any thoughts?
10 REPLIES 10
MatthewWheeler
Fixes: 480
Re: Consistantly slow fibre speed
Our tests are showing a profile mismatch on your line.
I'm getting that raised for you.
 Matthew Wheeler
steve57
OK, thanks for your quick response.
steve57
OK, so now the download speed is actually worse.
steve57
Morning, Mathew
Could you tell me how long it will take to sort the profile mismatch we talked about on Friday?
Chris
Legend
Fixes: 169
Unfortunately the fault checker seemed to stall, so it's not reported the issue on correctly. I've just done that manually and we should have more information in the next 48 hours. Sorry for the delay.
steve57
Any update on our problem?
Thanks.
steve57
Morning,
I was wondering if there was any news on our problem?
steve57
Morning, any news on our problem from two weeks ago? Thanks.
rongtw
Fixes: 12
Well Acording to the forum there are 3 staff online Shocked
But they are avoiding posting Roll_eyes for some reason
steve57
A second visit by an Openreach engineer who changed an obsolete socket fixed the problem.
