Can I use a Draytek Vigor 2820 broadband router on fibre broadband?
- Can I use a Draytek Vigor 2820 broadband router on...
04-08-2016 5:36 PM
Hi I have just switched to fibre broadband and would like to know if I need a new modem router or if the Vigor 2820 will be able to connect to broadband fibre. If it does work what settings do I need to change to connect?
many thanks,
Re: Can I use a Draytek Vigor 2820 broadband router on fibre broadband?
04-08-2016 6:45 PM
Hi @Snubber
Welcome to the forums.
As Draytek say at http://www.draytek.co.uk/products/legacy/vigor-2820 the 2820 is an ADSL modem/router so you will need a new device of some sorts.
According to the above page, you could get a VDSL2 modem and just use the Draytek as a router connected via its WAN port to the new modem. I believe that VDSL2 modems are expensive though so you maybe better off getting a new all -in-one VDSL2 modem/router.
For a list of good all-in-one VDSL2 devices with a good discussion on the devices, I would suggest looking at kitz's forum at http://forum.kitz.co.uk/index.php/topic,14436.0.html
04-08-2016 7:23 PM
Yes you can use the Draytek 2820 however you will need a VDSL modem. you can get the huawei HG612 or the ECI b-focus B-2FUb/r (both as used to be supplied by openreach) off ebay for around £30. you need to plug the modem into the telephone socket and the modems LAN 1 to the Draytek WAN socket. You will need to set up the draytek with your username and password and change the connection settings from the PPPoA to PPPoe. I have a number of clients using this configuration without any problems ( I use the Draytek 2830 but otherwise the same)
04-08-2016 8:27 PM
I didn't think about buying an Openreach modem from ebay. I was just thinking about an VDSL2 modem that someone wanted that allowed multiple external IP's which was in the region of £140. Thank you for mentioning the obvious and much cheaper solution.
06-08-2016 9:24 AM
Performance in terms of speed is the same, or slightly better, than the Hub One on my line 58/16 on the 80/20 product.
The Draytek site has detailed instructions for use of the 2820 on BT fibre. I was contemplating buying the 2860 to get a one box solution but the 2820 and modem is good enough to stick with.
