Buffering and packet loss.
Itschin
Hello,
I am getting very bad packet loss when playing games and buffering when watching streaming sites youtube, twitch, netflix
Is there any status notices for problems known, that I wasnt able to find.
This has just recently started happening without me changing anything.
How would I report packet loss and routing problems?
11 REPLIES 11
adamwalker
Fixes: 221
Re: Buffering and packet loss.
Is this affecting you over a wired or wireless connection?
Also have you checked to see if your downstream speeds are slower than usual?
 Adam Walker
Itschin
Hello adamwalker
I am using wired connection
my download speed seems to be normal
I am getting 10%+ packet loss to various IPs that I have been able to check, is there somewhere I can report this?
Here is an example
|                                      WinMTR statistics                                   |
|                       Host              -   %  | Sent | Recv | Best | Avrg | Wrst | Last |
|                           dsldevice.lan -    0 |  128 |  128 |    0 |    0 |    2 |    0 |
|                   No response from host -  100 |   26 |    0 |    0 |    0 |    0 |    0 |
|      129.hiper04.sheff.dial.plus.net.uk -   93 |   28 |    2 |   16 |   17 |   18 |   16 |
|              be3-3100.pcn-ir01.plus.net -    0 |  128 |  128 |   16 |   16 |   18 |   16 |
|       core1-BE1.colindale.ukcore.bt.net -    0 |  128 |  128 |   15 |   16 |   18 |   16 |
|                           195.99.127.83 -   15 |   81 |   69 |    0 |   17 |   20 |   17 |
|       t2c3-et-3-1-0-0.uk-lon1.eu.bt.net -    0 |  128 |  128 |   16 |   17 |   26 |   17 |
|   ae5.cbs01.tg01.lon01.networklayer.com -   34 |   56 |   37 |   16 |   17 |   20 |   17 |
|   ae0.cbs01.xn01.fra01.networklayer.com -    0 |  128 |  128 |   30 |   31 |   38 |   31 |
|   ae0.cbs02.ic01.mil02.networklayer.com -    0 |  128 |  128 |   40 |   41 |   49 |   41 |
|       ae21.dar01.mil01.networklayer.com -    0 |  128 |  128 |   39 |   40 |   77 |   40 |
|       po1.fcr01a.mil01.networklayer.com -    0 |  128 |  128 |   41 |   41 |   45 |   41 |
|    f4.8e.7a9f.ip4.static.sl-reverse.com -   10 |   93 |   84 |    0 |   40 |   43 |   40 |
|________________________________________________|______|______|______|______|______|______|
Strat
Fixes: 565
Moderator's note by Dick (Strat)  Posts released from spam filter and surplus ones removed.
Itschin
Hello,
The online chat system seems to be unavailable at the moment, is there anywhere I can report packetloss problems?
email or telephone?
thanks
i
Kelly
Fixes: 9
What IP is that trace to?
That's telling me you don't have an issue because all the packets are making it to the 2nd to last address in the list.  (i.e. 128/128 packets were sent and received there).  That means the loss is outside our network and much further on.
The fact that you're seeing issues across a bunch of services though suggests you've a more general issue.  What's your broadband speed looking like?
Kelly Dorset
Ex-Broadband Service Manager
Itschin
Hello Kelly,
My speeds are around normal amounts.
The example I gave was to "mil.login.pathofexile.com", this is one I gave because playing games is where its obvious to see the effects.
My problem is packetloss based, its more of things not loading properly on the first attempt, buffering on youtube and twitch.tv. After 2-3 refreshes its possible to get videos going.
I will try tonight to see if I can find if its just to certain places or a more general thing.
Kelly
Fixes: 9
Anyone else seeing any packet loss to mil.login.pathofexile.com?  I'm seeing no issues from our office lan.
Kelly Dorset
6.5Mbps ADSL on peak time congested 20CN exchange.
Wired connection for MTR test
Internet connection also streaming a Netflix film in SD for duration of MTR test
I ran the MTR test three times, and got near identical results each time.
It looks OK to me -
$ mtr -c 1000 mil.login.pathofexile.com
Start: Thu Dec 14 20:02:23 2017 HOST: Nibiru Loss% Snt Last Avg Best Wrst StDev 1.|-- nibiru-gateway 0.0% 1000 0.4 0.4 0.4 0.9 0.0 2.|-- 410.xe-2-2-0.central10.pcn-bng03.plus.net 0.0% 1000 30.0 34.3 25.9 107.4 12.8 3.|-- 411.be7.pcn-ir02.plus.net 0.0% 1000 31.3 34.2 27.0 104.1 12.2 4.|-- 195.99.125.140 0.0% 1000 30.0 34.6 26.6 93.4 12.5 5.|-- 195.99.127.83 0.0% 1000 32.3 34.9 27.3 101.3 11.9 6.|-- t2c3-et-8-1-0-0.uk-lon1.eu.bt.net 0.0% 1000 30.2 35.0 27.1 94.5 12.3 7.|-- ??? 100.0 1000 0.0 0.0 0.0 0.0 0.0 8.|-- ae5.cbs01.tg01.lon01.networklayer.com 59.2% 1000 37.5 36.6 28.9 99.3 11.9 9.|-- ae0.cbs01.xn01.fra01.networklayer.com 0.0% 1000 46.1 50.6 42.5 117.1 12.9 10.|-- ae0.cbs02.ic01.mil02.networklayer.com 0.0% 1000 54.9 60.0 52.0 118.6 12.8 11.|-- ae21.dar01.mil01.networklayer.com 0.0% 1000 54.4 59.8 51.2 154.6 13.5 12.|-- po1.fcr01b.mil01.networklayer.com 0.0% 1000 54.5 59.2 51.4 120.1 12.4 13.|-- f4.8e.7a9f.ip4.static.sl-reverse.com 0.0% 1000 54.6 58.5 51.2 124.9 12.7
Itschin
Yeah it must just be me. Maybe my local telephone exchange has a cable that came out.
|                                      WinMTR statistics                                   |
|                           dsldevice.lan -    0 |  102 |  102 |    0 |    0 |    1 |    0 |
|                   No response from host -  100 |   21 |    0 |    0 |    0 |    0 |    0 |
|      129.hiper04.sheff.dial.plus.net.uk -   87 |   23 |    3 |    0 |   20 |   31 |   15 |
|              be3-3100.pcn-ir01.plus.net -    0 |  102 |  102 |   15 |   15 |   17 |   15 |
|                          195.99.125.136 -   16 |   66 |   56 |   15 |   16 |   24 |   16 |
|  peer2-et-1-3-0.telehouse.ukcore.bt.net -    0 |  102 |  102 |   16 |   16 |   39 |   16 |
|                           195.99.126.71 -   14 |   67 |   58 |   15 |   16 |   56 |   16 |
|                ae0.er01.cwwtf.bbc.co.uk -    3 |   95 |   93 |   17 |   18 |   44 |   18 |
|                         132.185.255.164 -    7 |   83 |   78 |   18 |   18 |   30 |   18 |
|              bbc-vip016.cwwtf.bbc.co.uk -    5 |   87 |   83 |   17 |   18 |   30 |   18 |
|                                      WinMTR statistics                                   |
|                           dsldevice.lan -    0 |  468 |  468 |    0 |    0 |    2 |    0 |
|                   No response from host -  100 |   94 |    0 |    0 |    0 |    0 |    0 |
|      129.hiper04.sheff.dial.plus.net.uk -   98 |   96 |    2 |    0 |   16 |   16 |   16 |
|              be3-3100.pcn-ir01.plus.net -    0 |  468 |  468 |   15 |   16 |   30 |   16 |
|       core1-BE1.colindale.ukcore.bt.net -    0 |  468 |  468 |   15 |   15 |   30 |   16 |
|                           195.99.127.83 -   10 |  341 |  309 |   16 |   17 |   20 |   17 |
|       t2c3-et-3-1-0-0.uk-lon1.eu.bt.net -    0 |  468 |  468 |   16 |   16 |   55 |   17 |
|   ae5.cbs01.tg01.lon01.networklayer.com -   72 |  121 |   34 |    0 |   17 |   21 |   17 |
|   ae0.cbs01.xn01.fra01.networklayer.com -    0 |  468 |  468 |   30 |   31 |   44 |   30 |
|   ae0.cbs02.ic01.mil02.networklayer.com -    0 |  468 |  468 |   39 |   40 |   55 |   40 |
|       ae21.dar01.mil01.networklayer.com -    0 |  468 |  468 |   39 |   41 |  113 |   40 |
|       po1.fcr01a.mil01.networklayer.com -    0 |  468 |  468 |   40 |   41 |   58 |   41 |
|    f4.8e.7a9f.ip4.static.sl-reverse.com -    6 |  391 |  371 |   39 |   39 |   55 |   40 |
|                                      WinMTR statistics                                   |
|                           dsldevice.lan -    0 |  128 |  128 |    0 |    0 |    1 |    0 |
|              be3-3102.pcn-ir02.plus.net -    0 |  128 |  128 |   15 |   16 |   61 |   15 |
|                          195.99.125.140 -    0 |  128 |  128 |   15 |   17 |   62 |   16 |
|   peer1-hu0-19-0-2.slough.ukcore.bt.net -    0 |  128 |  128 |   15 |   17 |   63 |   15 |
|        po111.net1.north.dc5.as20860.net -    0 |  128 |  128 |   17 |   25 |  167 |   18 |
|             1717.g1.1ug.dc5.as20860.net -    4 |  112 |  108 |   17 |   20 |   80 |   19 |
|                           109.169.19.90 -   15 |   80 |   68 |   17 |   18 |   41 |   17 |
Kelly
Fixes: 9
Yeah, I think you need to raise a fault with us.  (First make sure you've checked direct into the router to eliminate wiring/wifi etc)
http://faults.plus.net
Kelly Dorset
Kelly
Fixes: 9
@Anonymous wrote:
thanks! Cheesy
Kelly Dorset
