cgi form email script not working (404)
- Everything else
- Re: cgi form email script not working (404)
11-10-2014 8:26 PM
Hopefully it won't be long before its resolved, thanks
13-10-2014 10:50 AM
Quote from: cyberdynesystems I have noticed that I now have an extra setting under my account, website settings: plusnet hosting (cgi), of course that takes me to the same log in page linked above. Under user name it indicates using the email address, so I've tried that too but can't log in still, not sure what else to try, but feel I'm really close if like Irien above I can get the help to log in and get access.
It looks like it is your email address you'll need to use to log in. I've tried at this end and it does work. You'll need to use the email address you have registered here.
Hope that helps.
13-10-2014 4:01 PM
14-10-2014 10:17 AM
- The problem is unlikely to be resolved ; ie http://homepages.plus.net/cgi-bin/form won't be available in future
- The only option is to move my website to the cgi platform and set up my own email script
14-10-2014 12:09 PM
I'm sorry it's taking so long to arrive at that decision
15-10-2014 8:41 AM
Is the security issue in the platform or the email script from 'Matts Script Archive'?
If the latter, is it just PlusNET's implementation, as this script is somewhat generic, widely used and if implemented individually on the new cgi platform is just going to perpetuate the issue.
Not fixing it will be another nail in the coffin of PlusNET no longer offering webspace within what used to be stunningly good internet packages. I have just noticed that web space has now been dropped from the business packages too, which means that i can no longer recommend this as a good all round package, to a new business start-up venture. It had everything they required - internet, phone, email, small amount of web space, domain name hosting and a web to email script... half of the value-add is gone.
Very disappointing!
Kevin
15-10-2014 9:51 AM
Edit: Forgot to mention, Business products *do* come with a webspace entitlement.
15-10-2014 11:51 AM
Thank you fir the clarification on the business packages - it is not obvious any more on the package 'headlines' - on rechecking I find it is now hidden under "All inclusive features"!
Kevin
17-10-2014 12:26 PM
Quote from: gandb I've only just noticed the problem (cgi form email script not working ) on our website and just read this topic. Am I right to conclude that:
I've left my website in its original place, just edited the form to show the scripts new location in my cgi bin (matts form mail script). Had to set the form script up also, not straight forward at first but i've done it now
29-10-2014 10:56 PM
There is an alternative: the nms project at http://nms-cgi.sourceforge.net has the script nms formmail. This is recommended by the author of the form script, and is provided instead of form by a number of ISPs word-wide. It is obviously more complex to set up, but I assume the many extra security features will harden it against spammer or hacker. I do not know if any of these have been incorporated into your form script.
Richard
30-10-2014 10:12 AM
Quote from: richux There is an alternative: the nms project at http://nms-cgi.sourceforge.net has the script nms formmail. This is recommended by the author of the form script, and is provided instead of form by a number of ISPs word-wide. It is obviously more complex to set up, but I assume the many extra security features will harden it against spammer or hacker. I do not know if any of these have been incorporated into your form script.
Not sure if this is a customer recommendation or a recommendation for us/Plusnet? If the former, then it's not going to work on our Homepages servers because it requires the ability to run server side scripts which is unsupported by the platform.
30-10-2014 11:30 AM
Yes, a suggestion that PlusNet replace the out-of-date form script by formmail.
I know this does not solve the old-version bash problem, but plugs a few email exploits!
Richard
30-10-2014 1:36 PM
For the record, bash is patched, the situation has put a bit of a security spotlight on the Homepages scripts though (I don't think many people knew they were there). Some decisions still need to be made, really sorry it's taking so long!
31-10-2014 9:06 AM
Can I add my support for Richard's suggestion that PlusNet provides a new script to replace the old one please? Leaving my website with an apologetic note that "we're waiting for the hosting system to put things right: email instead of using the form" isn't a nice solution when it's being going on so long! The old form wasn't brilliant and I'd be quite happy to install a replacement from PlusNet.
Incidentally, was the 'visit counter' also a security threat? If not, can that be put back?
Thanks, Barry
31-10-2014 11:22 AM
- Everything else
