This site can’t be reached
nking
I have web space from PlusNet and I utilise CGI. My site is working except I am now getting an error when I access this address http://cgi.pcking.plus.com/metar-display.php . "
Hmmm… can't reach this page
ccgi.pcking.plus.com’s server IP address could not be found." .
Bob Pullen has successfully helped me in the past so I hope he can sort this out for me this time 🤞
26 REPLIES 26
PhilipHeyes
Aspiring Champion
Fixes: 15
Re: This site can’t be reached
Check that is the correct web address, because it lacks a DNS entry.
https://www.nslookup.io/domains/cgi.pcking.plus.com/dns-records/
nking
Thanks for your prompt response. It has been working OK for over two years and has now stopped working. I'm 72 years old so my brain cells don't function as well as I would like 😂 Here is the link from my website that until recently did work  http://pc-king.me.uk/links.htm then select "Local Airport METAR Weather Conditions"  Not sure how I can resolve this myself, I think it needs someone from PlusNet to fix it their end I imagine. Unless you know how it can be resolved?
PhilipHeyes
Aspiring Champion
Fixes: 15
Things usually break when a change or fault occurs.
In this case the content owners of :  http://cgi.pcking.plus.com/metar-display.php
need to re-create the DNS entry.for : cgi.pcking.plus.com
Fixes: 245
@nking
Nice site - I will escalate this.
nking
Thank you for your assistance.
bobpullen
Fixes: 330
Apologies, only just seen this.
I've hit something with a spanner and am fairly confident it will spring back to life in time for the New Year.
Have a good one 🎉
nking
Thank you Bob, it's up and running. Do you know why it broke?  Or do I just need to buy a spanner😉
Happy New Year
Neil
Fixes: 480
Getting hold of a spanner is the easy bit. Knowing precisely where and how hard to hit it is the really tricky bit!
bobpullen
Fixes: 330
I suspect the trigger was some unrelated account activity. Password change/reset being the likely one. This has a tendency to put the CGI service into a 'halfway house' of sorts that breaks the DNS records until somebody attends to it.
nking
I do recall changing a password so I think I caused the error to occur. Thanks again for resolving this 😉
nking
I have a problem accessing my main site - http://www.pc-king.me.uk/ . It comes back with -
Service Unavailable
The service is temporarily unavailable. Please try again later.
Can someone look at this for me. If Bob is available please let him know.
Many thanks
Fixes: 245
Have you been migrated to Greenby?
Fixes: 382
I can't reach it either, just constant 'waiting for "site" '.
nking
I can't answer your question,is this something I should be aware of?
