Request to move my domain from Plusnet
greybeard99
Having decided not to go with Greenby hosting, I wish to transfer my domain (to Hostinger). I have spoken to PN but the answer was almost we cannot change the IPSTAG. Fingers crossed, it looks like posting here will enable the process to happen. Would be very grateful if someone could pick this up. Advised that new ISP TAG should be AXIDOMAINS.
Thanks in advance for any assistance, let me know if more info required - not sure if you will be able to find my account
3 REPLIES 3
Marsh
Fixes: 41
Re: Request to move my domain from Plusnet
Hey @greybeard99,
I can get this started for you. I just need you to confirm some details on a ticket I created on your account. Here is a link to the question.
https://www.plus.net/wizard/?p=view_question&id=252298714
Josh
Fixes: 241
@James_B
Can the briefing / training for front line staff be reviewed please.  This is standard BAU and is likely to be a recurrent requirement.
*.uk require a change in IPSTAG
*.com require a transfer code
@Marsh - thank you for minding the gap again.
greybeard99
Hi Josh,
Apologies, I had a delay in actually getting in to my account with prospective hoster,  this is now resolved. Hopefully this question can be re-opened.
According to my account, the proposed transfer is set up, so I have already initiated the transfer as requested, and they are waiting for my provider (ie Plusnet) to update the ISP tag to AXIDOMAINS . Are you able to be more specific as to if there is anything further to do at new hoster?
Tim
