Static IP bolt-on activated but still showing dynamic
turnma
Hi.  As per the subject, I activated the static IP bolt-on a couple of days ago, rebooted the router, but when I click the "Configure Static IP" link in the portal I get told:
Current Status: You are currently using a dynamic IP address
The help pages say I don't need to contact anyone to activate the static IP, but underneath the text telling me I'm still dynamic it says:
If you'd like to add or remove a Static IP please  or call our Support Team on 0800 432 0200 or 0345 140 0200
That link takes me to a page that says "We're sorry, but you can no longer ask a question through the Help Assistant", so it looks like the documentation is all out of date!
Could someone please advise how I get the portal to reflect that I'm now allocated a static IP, if indeed I am, or how to activate the static IP if not?
5 REPLIES 5
adam945
Fixes: 113
Re: Static IP bolt-on activated but still showing dynamic
Hello @turnma
Thanks a lot for reaching out and I'm sorry for the inconvenience caused here. I've just refreshed the component on the account if you'd like to restart your router and give it another go. If that doesn't work, I'll remove and re-add the component on the account. Smiley
 Adam
 Plusnet Help Team - Leeds
turnma
Thanks for the help.  Unfortunately after another router restart it still shows the IP as dynamic in the portal.
Fixes: 1,641
Thanks for getting back to us @turnma
Try rebooting your router one more time. I've just removed and re-added the static IP.
I've also added a credit of £5 onto your next bill to cover the duplicate charge we'll automatically add.
Let us know how it goes.
turnma
That's done the trick, thanks! 😁
Fixes: 1,641
Excellent! Thumbs_Up Let us know if there’s anything else you’d need help with.
