Static IP bolt-on activated but still showing dynamic
FIXED- Subscribe to RSS Feed
- Everything else
- Static IP bolt-on activated but still showing dyna...
14-10-2021 7:17 PM
Hi. As per the subject, I activated the static IP bolt-on a couple of days ago, rebooted the router, but when I click the "Configure Static IP" link in the portal I get told:
Current Status: You are currently using a dynamic IP address
The help pages say I don't need to contact anyone to activate the static IP, but underneath the text telling me I'm still dynamic it says:
Adding or removing a Static IP
If you'd like to add or remove a Static IP please raise a Ticket or call our Support Team on 0800 432 0200 or 0345 140 0200
That link takes me to a page that says "We're sorry, but you can no longer ask a question through the Help Assistant", so it looks like the documentation is all out of date!
Could someone please advise how I get the portal to reflect that I'm now allocated a static IP, if indeed I am, or how to activate the static IP if not?
Fixed! Go to the fix.
Re: Static IP bolt-on activated but still showing dynamic
15-10-2021 8:32 AM - edited 15-10-2021 8:32 AM
Hello @turnma
Thanks a lot for reaching out and I'm sorry for the inconvenience caused here. I've just refreshed the component on the account if you'd like to restart your router and give it another go. If that doesn't work, I'll remove and re-add the component on the account. ![]()
15-10-2021 6:13 PM
Thanks for the help. Unfortunately after another router restart it still shows the IP as dynamic in the portal.
15-10-2021 6:19 PM
Thanks for getting back to us @turnma
Try rebooting your router one more time. I've just removed and re-added the static IP.
I've also added a credit of £5 onto your next bill to cover the duplicate charge we'll automatically add.
Let us know how it goes.
15-10-2021 11:33 PM
That's done the trick, thanks! 😁
15-10-2021 11:49 PM
Excellent!
Let us know if there’s anything else you’d need help with.
- Everything else
