New Static IP address seems to be blocked and PlusNet Helpdesk are unable to help!
Champnet
Fixes: 21
Re: New Static IP address seems to be blocked and PlusNet Helpdesk are unable to help!
Thanks, so the problems either the router port forward or the web server not listening....
@piphind In the port forward rule try changing  the device name to it's IP address.
Mook
Seasoned Champion
Fixes: 9
piphind
On the account page temporarily untick the ‘enable auto block’ as you may be blocking everybody.
On the same page are there any entries in the allow/block list ?
Turning off the "enable auto block" has no effect
Nothing in the Allow/block lists
piphind
Done. No impact!
Champnet
Fixes: 21
I don’t know the router, do have have to re-boot it after making changes ?
You should not need to reboot the Hub One for the changes to take.
piphind
A  big thanks to everyone who made suggestions.
It would appear that there was something not quite right with either my network wiring or the Synology set-up.
I ended up moving some of the connections to try and eliminate part of the network (e.g. I run a Mesh for my WIFI rather than use the Router WiFi). I also reviewed all of the Synology settings and turned a few thing off then on again).
The result .......
It's now working fine !!!!!!
Champnet
Fixes: 21
On the account page re-enable the ‘enable auto block’ .
Project for the future : look at changing port 80 to port 443 for stronger security.  It’s not easy but there’s a lot of help on the Synology forums.
