How do I specify DNS Address field when Domain hosting is set to other
FIXED- Subscribe to RSS Feed
- Everything else
- Re: How do I specify DNS Address field when Domain...
05-04-2026 5:56 PM
I have set my domain hosting settings to other. I want to set up an "A" (Address) record to point to an IP address.
Looking at other DNS entries I would expect to use @ for the left field, but if I try this is says that only ". a-z - 0-9" are allowed. If I specify the full domain name it still does not work and seems to setup the domain "domain name"."domain name" almost as if I should set it to blank which is not allowed.
There did seem to be an article on this issue but it had been archived so I cannot access it.
Fixed! Go to the fix.
05-04-2026 6:58 PM
You need to add a qualifying dot on the left hand side, i.e: -
domain.tld. A <ip_address>
- Everything else
