Hosting Bahind a BT Voyager router...
- Everything else
- Hosting Bahind a BT Voyager router...
23-05-2008 12:16 AM
I sent this message to plusnet, and they jsut referred me to the community forums, figures
"I have forwarded port 80, I have set my internal IP as the virtual server, and you cannot access the router from a remote location, so why after all this do when I go to http://bigfootmech.dyndns.org I get my router settings? - and yes I've checked that going to 192.168.1.4 (my internal address) as opposed to me external address shows me my website.
Please tell me anything that I actually need to do to get this hog of a router to let me host a server bahind it.
PS: the BT Voyager 2110 router came with our package."
Anyone that can help me with my problem please post, all comments welcome. Also please don't just say "buy a new router" as this is not a real solution, I got this router with plusnet and so far it hasn't given out. i've had 2 other linksys routers 1 still sorta works I think but it was definately breaking the connection very often which was a right pain. Plus I'm not very willing to shell out more of my meager allowace for a router if it can be done another way.
Re: Hosting Bahind a BT Voyager router...
23-05-2008 7:48 AM
You probably won't be able to check it from another machine (or the same machine) on your own LAN as the BT 2110 probably can't manage an "out and in" route.
Can you check it from another internet connection to test it? Say a friend or from college or work?
I've tried going to your site and to the IP associated with it only to have it time out and give a 404 -- but you may have given up or your server might not be running or whatever, so that might not prove anything.
I don't use that router so can't be more specific.
paul
23-05-2008 8:01 AM
I use http://www.guardster.com/ . you need the one at the bottom of the page "Free Anonymous Web Proxy"
23-05-2008 1:10 PM
It's really frustrating as I've googled it and loads of people seem to have a similar problem but I'm seeing no solutions!
I've done this before with a linksys router and had almost no problems whatsoever. BT FTL >:(. I don't even know why plusnet gave me this router o0.
23-05-2008 3:19 PM
I installed Abyss Web Server X1, set up a test site and then tried accessing the server from work. I was able to browse to the test site by setting up a single port forwarding rule as per the attached screengrab (config > virtual server > port forwarding).
The only other thing you might want to check is any IP filtering rules you have configured (config > security > ip filter)
23-05-2008 4:16 PM
That is a fabulous little multiplatform server
23-05-2008 4:48 PM
23-05-2008 5:14 PM
23-05-2008 6:27 PM
24-05-2008 12:58 PM
24-05-2008 1:45 PM
pd
25-05-2008 12:55 PM
25-05-2008 2:04 PM
06-10-2008 4:28 PM
The Voyager 2091 is not the problem (in fact, I think it's one of the best home routers I've had). Plus.net has a "Broadband Firewall" that is set in "Low" as a default, not letting pass port 80, as well other ports. You need to go set your Broadband Firewall to off to do this.
I don't think I need to remind you the grave risk you're going at, so please secure your computers with either a local firewall or a good network monitor.
Cheers.
- Everything else
