Domains - Transfer Out Query
- Everything else
- Domains - Transfer Out Query
03-11-2008 1:14 PM
I have a domain that I have owned for the last number of years.
Originally it was hosted on plusnet, but then I moved the files etc over to another company.
When I look in My Account details (under the Domains section) it says:
Domain Name babybmw.net
Status Registered and Hosted
And it gives the option of Configure or Transfer Out
Under Configure, there are no references at all to the current company that I use.
If I do a WHOIS of the domain, it brings the following back:
Registrar: 1 & 1 INTERNET AG
Whois Server: whois.schlund.info
Referral URL: http://registrar.schlund.info
Expiration Date: 2010-01-07
Creation Date: 2004-01-07
Last Update Date: 2008-09-08
Name Servers:
ns33.1and1.co.uk
ns34.1and1.co.uk
My question is.....what happens if I hit "Transfer Out"??????
The reason I am questioning this is that I am considering leaving Plus Net and am concerned that if I do, the domain wont work any longer
Thanks for any help
Colin
Name Servers:
ns33.1and1.co.uk
ns34.1and1.co.uk
Thanks for any help
Colin
Message 1 of 2
(915 Views)
1 REPLY 1
Re: Domains - Transfer Out Query
08-11-2008 12:38 PM
Hi Colin,
The domain is neither registered or hosted with us any more so there is no need for it to be associated with your account. I've removed it and it should no longer be visible in the Member Centre.
Message 2 of 2
(287 Views)
- Everything else
