DNS issue
triwebdesign
DNS issue
On Friday I was trying to get my website to point to another page by playing with the DNS settings. In the end I added a htm page which did the redirect.
On Saturday everything broke!
Sunday I removed all the DNS records in the Advanced section.
Monday night still broke!
I am guessing I removed the correct DNS records in the process.
I have done the following
mydomain.co.uk A 212.159.8.91
www cname mydomain.co.uk
Does this look right? Anything I need to do apart from wait for the servers to propagate?
The domain name just needs to point to mydomain.plus.com on 212.159.8.91
24 REPLIES 24
spraxyt
Resting Legend
Fixes: 75
Re: DNS issue
It looks like you missed off the full stop after mydomain.co.uk which is essential in each of those records. These are needed to stop the system adding the domain name again and duplicating the field entry. Note that no full stop is required after www . In this case the system *will* add the domain name, but that is what is needed.
David
David
triwebdesign
Re: DNS issue
So it should be?
My domain.co.uk. A 212.159.8.91
May be worth noting my domain and website is hosted by PN.
triwebdesign
Re: DNS issue
Will I need to add a MX records? Don't recall seeing any before for my domain emails.
Chris
Legend
Fixes: 169
Re: DNS issue
If all you're trying to do is this:
Then you don't need to set up *any* DNS records. This happens by default, in fact setting up the record to point at that IP will probably stop it working.
If you then wanted www.mydomain.co.uk too you just need to set up a CNAME (which you have done correctly).
I've removed the erroneous record and you should find this starts working within 24 hours, as long as no additional records are set up.
triwebdesign
Re: DNS issue
Thank you Chris.
I assume this will fix my email too so I can use my domain email address as oppose to plus.com version?
triwebdesign
Re: DNS issue
Still not working. Over 24 hours later.
triwebdesign
Re: DNS issue
48 hours. Nothing.
Chris
Legend
Fixes: 169
Re: DNS issue
I've checked on this today and unfortunately there are simply no domain records being created, I've had to pass this on to a backend team to investigate and resolve. To set the right expectations, this might not happen until after the weekend.
triwebdesign
Re: DNS issue
How do I check on the progress, Chris? On here?
bobpullen
Fixes: 316
Re: DNS issue
Bump the thread tomorrow afternoon and I'll make sure it's been attended to. I suspect all the recent changes are stopping the zone from reloading.
triwebdesign
Re: DNS issue
Will do Bob
bobpullen
Fixes: 316
Re: DNS issue
Trying to chase this up for you now.
triwebdesign
Re: DNS issue
Bump!
bobpullen
Fixes: 316
Re: DNS issue
It's going to need a change control raising I'm afraid. Looking like Tuesday at the moment (may need to wait a while for DNS to propagate when it's fixed too).
Sorry for not being able to sort anything out sooner Undecided
