DNS issue
- Everything else
- Re: DNS issue
DNS issue
11-01-2016 8:38 PM
On Saturday everything broke!
Sunday I removed all the DNS records in the Advanced section.
Monday night still broke!
I am guessing I removed the correct DNS records in the process.
I have done the following
mydomain.co.uk A 212.159.8.91
www cname mydomain.co.uk
Does this look right? Anything I need to do apart from wait for the servers to propagate?
The domain name just needs to point to mydomain.plus.com on 212.159.8.91
Re: DNS issue
12-01-2016 12:32 AM
David
Re: DNS issue
12-01-2016 6:06 AM
My domain.co.uk. A 212.159.8.91
May be worth noting my domain and website is hosted by PN.
Re: DNS issue
12-01-2016 6:15 AM
Re: DNS issue
12-01-2016 9:00 AM
Quote The domain name just needs to point to mydomain.plus.com on 212.159.8.91
Then you don't need to set up *any* DNS records. This happens by default, in fact setting up the record to point at that IP will probably stop it working.
If you then wanted www.mydomain.co.uk too you just need to set up a CNAME (which you have done correctly).
I've removed the erroneous record and you should find this starts working within 24 hours, as long as no additional records are set up.
Re: DNS issue
12-01-2016 2:22 PM
I assume this will fix my email too so I can use my domain email address as oppose to plus.com version?
Re: DNS issue
13-01-2016 7:28 PM
Re: DNS issue
14-01-2016 2:51 PM
Re: DNS issue
14-01-2016 3:29 PM
Re: DNS issue
14-01-2016 6:23 PM
Re: DNS issue
14-01-2016 7:08 PM
Re: DNS issue
15-01-2016 9:49 AM
Re: DNS issue
15-01-2016 12:52 PM
Re: DNS issue
15-01-2016 10:34 PM
Re: DNS issue
15-01-2016 10:55 PM
Sorry for not being able to sort anything out sooner
