email problems - receiving
billswan
Re: email problems - receiving
I've logged in to webmail, and there are just a few (7) emails - mostly from Plusnet telling me, monthly, that my PN bill is available.  There were just two there yesterday, so the rest have been 'unarchived'!
There is nothing in deleted or other mailboxes.
And still no emails appearing in my MS:Outlook client (silent since 25/5).
I'm pretty sure I'm using POP3, and usually just download to my local client.  Not sure what the setting is for deletiob from server.
plusnettony
Fixes: 74
Sounds like you're logging into the Plusnet account not the Metronet one in webmail.
In your mail client, do you get any error?
 Tony T
billswan
It's the same webmail login I've always used.  Not sure what Metronet is.
No error report when I click 'send/receive' in MS:Outlook; just nothing there to find, apparently
plusnettony
Fixes: 74
Apologies, I meant Global not Metronet.
 Tony T
billswan
I've checked, and the account which I'm logged into is, apparently
I haven't changed anything, so I'm assuming this is how I've always accessed my account, which is
But, frankly, I'm already past what little technical ability I have (sorry)
And how would that affect the mail delivery to my MS:Outlook client?
plusnettony
Fixes: 74
I've sent test to your Global email address. I can't check the contents of that.
Your Plusnet one - has in it, the amount you posted earlier and appears to be working fine.
For a test, before looking at outlook, go to webmail.plus.net, enter your full global email address in the top box, your password and select Plusnet in the drop down. See if that shows the emails you are expecting (or my test). Also worth editing out your email address on this page.
 Tony T
billswan
Ooops - OK - done that.
I've tried logging in as you said, but get just a message 'login failed'.  Can you discern anything from that?  I assume that, if the password is wrong then it would say so.  I've tried the last two that I know.
billswan
Does anybody know where my emails from the last two weeks might have gone, and how I can regain access to them, please?
plusnettony
Fixes: 74
Can you get in to the MAAF portal - https://secure.madasafish.com/myaccountdx/summary/
If not, we might need to reset the password.
 Tony T
billswan
Yes.
It has my Client ID and Service ID
Fixes: 1,662
Just to confirm, when logging into https://webmail.plus.net are you using your full Globalnet email address and the same password you used to log in to the Madasafish website?
billswan
Yes.
Just tried it afresh, and it returned 'Login failed'
Fixes: 1,662
I've made some changes (I've refreshed & re-configured the email component).
Could you try signing in again in about 30 minutes?
billswan
Of course.
I do need to go out (for a medical appointment) at 12.45.  I'll try before then
billswan
I just tried again to log in to webmail.
Disappointingly, same message in response: 'Login failed'.
I'm sorry, but I need to go to that appointment now.  If there's anything else you can do/think of I'd really like to be able to access my email when I return - before the weekend.
In the meantime, thank you.
