Problems with Webmail
rongtw
Fixes: 12
Re: Problems with Webmail
https://community.plus.net/t5/Service-Status/Planned-Website-Maintenance-13th-March-23-00-14th-March...
MKSlinky
Seasoned Pro
@rongtw
There's probably a time difference where you live, are you on this side of the equator? Seems to be working here in MK but nothing out of the ordinary. The service still craps out if you navigate through more than two folders.
rongtw
Fixes: 12
@MKSlinky well yes i do live in Bradford Smiley  Yorkshire
Moderator's note by Adie (Dvorak) amended post to remove inappropriate wording.
MKSlinky
Seasoned Pro
Well maybe you should count yourself lucky, due to your location you're probably being worked on first. Either that or it's just too wet in Yorkshire and your cables have gone rusty. Grin
bobpullen
Fixes: 316
@bobpullen wrote:
@rongtw, the software update has been rescheduled to next Tuesday.
Morning all. FYI, the software upgrade was completed this morning. It brings with it a few new features, like a checkbox selector, toast notifications, mailto link association and some other bits and pieces. You'll also notice some subtle aesthetic differences as the styling's been tidied up a bit.
Shout up if you spot anything untoward (beyond the current performance issues that is!)
VileReynard
Fixes: 20
What's a toast notification?
Isn't this a case of "fiddling whilst Rome burns"? Sad
Browni
Aspiring Hero
Fixes: 60
They pop up!
rongtw
Fixes: 12
Must admit @bobpullen it looks better Smiley
Time will tell if it performs better
Anon
Whilst I can, slowly, get into webmail, today I cannot get my Pnet email on my desk top mail and I could last night. What have you done now?
Whatever happens always remember "We will do you
.........................proud" say Pnet.
bazzer
A tick box and a light shade of blue are the changes I can see.
The slow / non response time to open an email is just as bad.
Would it not have been time better spent getting the damn webmail to work and then tinker with the colour palette?
Unbelievable.
MauriceC
Resting Legend
Fixes: 17
Ah!  But they can now demonstrate that progress is being made.  Shocked
JonoH
Fixes: 157
Just to be clear we did advise that this software update was not going to fix all the problems that our users are experiencing with webmail.
Work continues behind the scenes and by different teams to get the service back to where it needs to be.
 Jono H
 Plusnet Community Manager
VileReynard
Fixes: 20
I see the automatic drop down "feature".
Unfortunately, it includes a couple of "test" mailboxes that were deleted several weeks ago. Cry
username+test
username+test2
Anon
As I said, I can get into my mail on the web, but my desk top mail client will not get anything now. I repeat what have Pnet done this time that creates this mess for me.
Just keeps saying "your pop3  server has not responded in 60 seconds". When I ask it to keep trying it keeps bringing the same message back every 60 seconds.
MKSlinky
Seasoned Pro
My webmail is syncing relatively quickly using Windows 10 Mail app, the only thing amiss which I've noticed recently is that not all my messages are downloaded. For instance just now my mail app received around 15 messages in total yet my inbox on Webmail says I have 41 messages! Crazy or what? Crazy2
