Problem Setting up Outlook 2010
gordonb27
Just signed up today, so I'm not on the Plusnet network yet.
Been going around in circles trying to setup Outlook within Office 2010.
After the second image it just goes around in an endless loop, until I cancell it, then I'm told my username/password is being rejected by the server, needless to say these are not wrong.
I'm attaching screen shots to see if anyone can spot what's wrong or make any suggestions.
10 REPLIES 10
Strat
Fixes: 565
Re: Problem Setting up Outlook 2010
Possibly because you are still on the Talk Talk network.
When is your 'go live' date?
gordonb27
Not received an activation date yet.
I thought the authentication settings I've input allowed to login from anywhere.
Legend
Fixes: 257
They will, when you are connected to PlusNet - i.e. your service is activated.
gordonb27
So that means the only way I can keep track and check of my activation progress is via Webmail, is that correct?
Legend
Fixes: 257
What email address did you give to PN when you signed up? I gave them my then-current email, and received update &c notifications via that.
spraxyt
Resting Legend
Fixes: 75
Before broadband service activation you can receive messages sent to your Plusnet address but can't send via the Plusnet SMTP relays (because authorisation is allowed only on an activated account).
To set this up in Outlook you need to turn off "use same settings as my incoming mail server". For sending emails supply the hostname and whatever is appropriate for your current service provider's SMTP server.
David
Legend
Fixes: 257
Thanks  spraxyt - it's that long ago since I moved, I don't remember the instruction you have just given, but I thought there was a way. Smiley
gordonb27
Thanks for that, |I should have realised that  Embarrassed
I'll change the server settings when I get home.
For some strange reason the webmail site takes an eternity to load anything other than the initial screen, also all messages are duplicated.
Thanks fo the help folks.
w23
Fixes: 4
If webmail speed is a problem, try the 'old' version: https://webmail.plus.net/squirrelmail/src/login.php
Call me 'w23'
gordonb27
Thanks w23 you're not wrong that is much better. Cool
