Problem Setting up Outlook 2010
- Problem Setting up Outlook 2010
16-12-2015 8:54 PM
Been going around in circles trying to setup Outlook within Office 2010.
After the second image it just goes around in an endless loop, until I cancell it, then I'm told my username/password is being rejected by the server, needless to say these are not wrong.
I'm attaching screen shots to see if anyone can spot what's wrong or make any suggestions.
Re: Problem Setting up Outlook 2010
16-12-2015 9:55 PM
When is your 'go live' date?
17-12-2015 12:57 AM
I thought the authentication settings I've input allowed to login from anywhere.
17-12-2015 8:09 AM
17-12-2015 6:56 PM
17-12-2015 7:05 PM
17-12-2015 7:18 PM
To set this up in Outlook you need to turn off "use same settings as my incoming mail server". For sending emails supply the hostname and whatever is appropriate for your current service provider's SMTP server.
17-12-2015 7:51 PM
18-12-2015 10:23 AM
I'll change the server settings when I get home.
For some strange reason the webmail site takes an eternity to load anything other than the initial screen, also all messages are duplicated.
Thanks fo the help folks.
18-12-2015 10:46 AM
18-12-2015 4:01 PM
