How many email boxes
FIXED- Subscribe to RSS Feed
- How many email boxes
25-04-2016 3:59 PM
What is the maximum number of email addresses can you have ?
For example you can set up mail addresses as usernameone@plusnet.com
usernametwo@plusnet.com
usernamethree@plusnet.com
etc, etc,
but there must be a limit to the number or total size of usage per member ?
Why would you want to set up numerous mail addresses ? well many sites pester you for a email address should you wish to register with them or make a purchase which often results in you getting tons of junk mail which can exceed several hundred on return from holiday, to my knowledge there is no way to delete a current email address so the easiest way is to start a new one.
I may have got one or more points wrong regarding the above due to my lack of knowledge but would be interested in any replies or corrections to the above.
Fixed! Go to the fix.
25-04-2016 4:07 PM - edited 25-04-2016 4:09 PM
there is a limit to the amount of storage used but for number of mailboxes I have never heard of of any restrictions
However not in the format you are using
It is
box1@username.plus.com
box2@username.plus.com
box3@username.plus.com
etc.
Re: How many email boxes
25-04-2016 6:21 PM
I currently have 37 mail boxes set up but I use many more email addresses than that in the format <name>@<PNdomainname>.plus.com
Many boxes have been blackholed due to the amount of junk I was getting.
I often use throw-away addresses such at <companyname>@<PNdomainname>.plus.com for the odd company that I contact just the once and the PN Catch-all option is used to ensure I don't miss them any replies.
Forum Moderator and Customer
25-04-2016 6:38 PM
Thanks for the responses, the throwaway address is a good idea.
