Gmail issue
Fixes: 250
Re: Gmail issue
Cutting things short: does Plusnet host your domain?
If yes, then use the add spf records fudge; if no then create a DNS record in your registrar’s system.
Surfer
Re: Gmail issue
As far as I am aware all my email goes through Plusnet and no issue except for Gmail.  I can receive Gmail, but cannot send Gmail as it bounces.  I use mail.plus.net for POP port 995 and SMTP relay.plus.net port 587 if that helps.
I am not very techy when it comes to this sort of issue so please bear with me.  Thanks.
