Avast VPN
busylizzie
Avast VPN
I enabled the Avast free VPN this morning. Everything seemed to be okay then I realised I couldn't send email using the Pegasus POP client. Receving email was fine. I disabled the VPN and the mail client started working again. So how can I send email whilst having the VPN enabled?
Is it a question of changing settings, or is it likely to be beyond tech limits?
P.s. the message I was getting when sending the email was "Socket read error 10053"
Any help gratefully accepted.
3 REPLIES 3
Fixes: 390
Re: Avast VPN
@busylizzie I haven't checked that error code, but I suspect that as the VPN will be presenting a non-PN IP address, to the server, you are being identified as a non-PN user.
Maybe try authenticating your connection, although I don't know if that will work.
Fixes: 585
Re: Avast VPN
@busylizzie  @jab1 has it spot on there, with the VPN active you will be sending from a non Plusnet IP address. You will need to set authentication on the outgoing server (SMTP) settings. Use the same username & password that you use for the incoming server. Having set authentication, it should work both with and without the VPN active
busylizzie
Re: Avast VPN
Thank you both. Changed the settings, enabled the VPN and everything appears to work. And quick responses too!
