Re: Peak time latency spikes - TAP3 Test failure
- News & Announcements
- Community Announcements
- Re: Peak time latency spikes
14-03-2013 11:40 AM
Is the TAP3 test using the BT test login (still not working btw
[Moderator's note by Jim (Oldjim) Title changed after split ]
14-03-2013 11:46 AM
14-03-2013 11:57 AM
Quote from: AndyH Is the TAP3 test using the BT test login (still not working btw ) the only way of knowing if the problem is in the BT or PN network?
Not as far as I know know. I could only get it to run by using by Pnet username and password in the router ( so connected to my standard account ).
Of course doing this returns an error at the end of the test.
Using the speedtest@speed e.t.c login either times out, or returns a DNS error. I tried multiple DNS configurations, both in the router and in winblows, all to no avail
Edit: Sorry, misread your post /facepalm
14-03-2013 12:04 PM
Would it be possible for you to provide a screenshot of the Tap 3 Test not working/failing?
14-03-2013 12:23 PM
See the attached
14-03-2013 12:29 PM
I appreciate that other providers may be having similar problems, however, from a Plusnet perspective, we need to provide our own information and supporting documentation.
There is some information that I've got on our end, I was just wanting to get a few screen grabs so I can send them as well.
Thanks AndyH
14-03-2013 12:31 PM
I would like to hope that no customers would ever need to use any TAP Test.
Not an ideal world though 😕
14-03-2013 12:35 PM
Quote from: Chris If I need to report this issue, I need evidence to support it.
AndyH's screenshots are exactly what I was getting. Are you happy with one set of screen grabs? Don't really want to disconnect from a gateway that has been reliable for the past week...
14-03-2013 12:36 PM
They will be fine thanks. I don't want you to hop gateways!
14-03-2013 12:58 PM
If any are in the wrong place please PM me
14-03-2013 1:18 PM
Will have a closer look once I have got back in from planting out my parsnips
14-03-2013 1:23 PM
Someone suggested 'testing' but I can't find any information anywhere to back this up.
14-03-2013 1:23 PM
14-03-2013 1:25 PM
14-03-2013 1:31 PM
