Plusnet fibre products launch today (19th April 2011) including new Pro Add-on
jelv
Fixes: 10
Re: Plusnet fibre products launch today (19th April 2011) including new Pro Add-on
Two and a half hours and only concluded by me using a blunt instrument is a funny definition of immediate!
Reconnecting didn't work - I'd already tried that before I got desperate and tried the realm switch.
Rather than disagreeing with me when I know damn well exactly what happened and it is documented I suggest that you should expend your efforts on determining why it didn't work as intended.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Mand
Do you happen to know which gateways you hit each time you reconnected? We are a little out of balance and some endpoints were very busy last night. I suspect this is what gave you the slow speeds tbh. I'm going to do some testing here though to make sure.
jelv
Fixes: 10
Unfortunately no.
I looked at the graphs (not realising they were broken) - if some of them were indicating potential problems I would have then checked my gateway and tried gateway hopping.
I've been on pcl-ag05 since about 10:45pm - was that busy last night?
jelv
Fixes: 10
Incidently, does this imply that the Pro add-on is beneficial in reducing the impact on a user when the system is out of balance?
Mand
Quote from: jelv
Doesn't look too bad on there for late evening. Does that coincide with your speed returning to 'normal', or were speeds low on there too?
Mand
Quote from: jelv
To a certain extent, but you'd still see reduced speeds across the board if the pipe is busy enough (as seems to be demonstrated by your experience).
jelv
Fixes: 10
Quote from: Mand
Quote from: jelv
That coincides with speeds returning to normal.
I've since reconnected a few times but seem to be always hitting pcl-something - any reason for that (here's betting the next one will not be pcl!)
jelv
Fixes: 10
With hindsight, between 8:15 when I activated Pro add-on and 10:45 when it finally kicked in I should have wiresharked something to prove it wasn't working.
Hindsight is a wonderful thing!
Is removal of the add-on 'instantaneous' and if so what happens with the billing?
Mand
It's removed as immediately as it's added ;). Billing for it is stopped immediately but you'd need to manually request a refund of the part-month fee at the moment.
jelv
Fixes: 10
So I could remove it, check that I can wireshark some silver or lower packets, put it back on and check that they are now gold - in theory!
Mand
In theory you could. Although the network isn't as busy now so I wouldn't expect the same drop in performance if/when you remove it. That may or may not make the test more useful, depends on what you're looking for I suppose.
I will be looking to test the service offer changes later on today to see how immediate the changes really are.
WWWombat
jelv - I like the way you trust the billing platform to be smart enough to not charge a second time  Wink
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
jelv
Fixes: 10
That was going to be my next question!
Mand
You'd be charged again (this is the way the add-on system works). What we'd like to happen is you should get an automated refund when you cancel the original add-on, but that's not the case right now and the refund would need to be manual.
JEB
I'm thinking of changing from the legacy Premier Option 1 product which I am currently on to Fibre Extra Pro.  I use Usenet quite a bit and was wondering if anyone could give me an indication of the real world speeds I will see on Usenet during peak hours, say 6:00 PM to 11:00 PM?  I know that Usenet traffic is managed as gold traffic, I am just uncertain what the real world speeds will be like.
Cheers
James
