Plusnet fibre products launch today (19th April 2011) including new Pro Add-on
- News & Announcements
- Community Announcements
- Re: Plusnet fibre products launch today (19th Apri...
Re: Plusnet fibre products launch today (19th April 2011) including new Pro Add-on
04-05-2011 9:38 AM
Reconnecting didn't work - I'd already tried that before I got desperate and tried the realm switch.
Rather than disagreeing with me when I know damn well exactly what happened and it is documented I suggest that you should expend your efforts on determining why it didn't work as intended.
04-05-2011 9:48 AM
04-05-2011 9:56 AM
I looked at the graphs (not realising they were broken) - if some of them were indicating potential problems I would have then checked my gateway and tried gateway hopping.
I've been on pcl-ag05 since about 10:45pm - was that busy last night?
04-05-2011 9:58 AM
04-05-2011 10:55 AM
Quote from: jelv I've been on pcl-ag05 since about 10:45pm - was that busy last night?
Doesn't look too bad on there for late evening. Does that coincide with your speed returning to 'normal', or were speeds low on there too?
04-05-2011 10:57 AM
Quote from: jelv Incidently, does this imply that the Pro add-on is beneficial in reducing the impact on a user when the system is out of balance?
To a certain extent, but you'd still see reduced speeds across the board if the pipe is busy enough (as seems to be demonstrated by your experience).
04-05-2011 11:16 AM
Quote from: Mand
That coincides with speeds returning to normal.
I've since reconnected a few times but seem to be always hitting pcl-something - any reason for that (here's betting the next one will not be pcl!)
04-05-2011 11:19 AM
Hindsight is a wonderful thing!
Is removal of the add-on 'instantaneous' and if so what happens with the billing?
04-05-2011 11:29 AM
04-05-2011 11:34 AM
04-05-2011 12:08 PM
I will be looking to test the service offer changes later on today to see how immediate the changes really are.
04-05-2011 12:17 PM
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
04-05-2011 12:23 PM
04-05-2011 12:56 PM
10-05-2011 9:23 PM
I'm thinking of changing from the legacy Premier Option 1 product which I am currently on to Fibre Extra Pro. I use Usenet quite a bit and was wondering if anyone could give me an indication of the real world speeds I will see on Usenet during peak hours, say 6:00 PM to 11:00 PM? I know that Usenet traffic is managed as gold traffic, I am just uncertain what the real world speeds will be like.
Cheers
James
