Gateway Checker Update
spraxyt
Resting Legend
Fixes: 75
Re: Gateway Checker Update
Thanks. Plusnet need to change the rDNS entry for 84.93.249.164 to reflect that it is now a gateway. Perhaps results from the network maintenance this morning link.
David
bobpullen
Fixes: 330
pcl-bng02 I believe. I've notified the relevant parties.
Anotherone
Champion
Fixes: 21
Hi all, quick question. When doing tracert's or Gateway debug, do the following examples that I've underlined relate directly to (specifically identify) particular end-points?
link3-central10.pcl-gw01.plus.net (84.93.249.164) 4.050 ms
link4-central10.pcl-gw02.plus.net (84.93.249.38) 4.643 ms
link12-central10.pcl-gw02.plus.net (84.93.249.118) 2.449 ms
bobpullen
Fixes: 330
Yes, namely:
pcl-bng02
ptn-bng02
pcl-bng04
You should find the rDNS of the latter two is now correct though.
Anotherone
Champion
Fixes: 21
Thanks Bob, so if I've asked and understood that correctly -
link2-central10.pcl-gw01.plus.net (84.93.249.164)
would be two different end points on pcl-bng02?
bobpullen
Fixes: 330
Oh right, I see what you're asking now Roll_eyes
The underlined part of the host names are virtual routers, however I'm not 100% sure on the relationship between that and the endpoints. I /think/ the BNG's might be a 1:1 relationship, but for the E320's it's definitely not (i.e. multiple end points can traverse the same virtual router).
jockwav
What,s this all about?.
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Posting the following information as a reply to the Gateway Checker Update topic in the Community Announcements forum will help us to diagnose the problem.
    109.159.254.203 (109.159.254.203) 4.916 ms
    195.99.126.183 (195.99.126.183) 4.466 ms
    ae1.pcl-cr02.plus.net (195.166.129.3) 5.225 ms
    link3-central10.pcl-gw01.plus.net (84.93.249.164) 4.655 ms
https://www.flickr.com/photos/james_bingham/
bobpullen
Fixes: 330
Same thing I replied to here. We need to update the DNS records for one (or more) of our gateways.
jockwav
Cheers Bob. Smiley Cheesy
beef68
acc1-10GigE-0-1-0-2.l-far.21cn-ipp.bt.net (109.159.249.40) 10.077 ms
peer2-ae-1.redbus.ukcore.bt.net (195.99.126.97) 9.969 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 9.982 ms
Anotherone
Champion
Fixes: 21
Another for pcl-bng02 by the looks.
spraxyt
Resting Legend
Fixes: 75
Thanks both. It's another instance of the one mentioned by Bob here.
David
David
pj2014
Which gateway
peer6-te0-0-0-10.telehouse.ukcore.bt.net (109.159.254.104) 5.199 ms
195.99.126.183 (195.99.126.183) 4.841 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 5.422 ms
ae2.pcl-cr01.plus.net (195.166.129.6) 4.792 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 4.817 ms
spraxyt
Resting Legend
Fixes: 75
Thanks. Another instance of pcl-bng02 needing DNS updating.
David
David
Riza
Quote from: pj2014
Which gateway
Also having this error  Wink I'm on BNG02; right? If so I need to hop as this gives me disconnections through nearly all evenings.
Btw; I do have Safeguard on if this is causing the inaccurate findings?
peer6-te0-10-0-8.telehouse.ukcore.bt.net (109.159.254.154) 6.247 ms
195.99.126.183 (195.99.126.183) 48.126 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 5.183 ms
ae2.pcl-cr01.plus.net (195.166.129.6) 4.650 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 4.744 ms
