Gateway Checker Update
Alucidnation
Re: Gateway Checker Update
ae1.pcl-cr01.plus.net (195.166.129.1) 2.676 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 3.103 ms
spraxyt
Resting Legend
Fixes: 75
Quote from: Riza
Btw; I do have Safeguard on if this is causing the inaccurate findings?
Posting the following information as a reply to the Gateway Checker Update topic in the Community Announcements forum will help us to diagnose the problem.
peer6-te0-10-0-8.telehouse.ukcore.bt.net (109.159.254.154) 6.247 ms
195.99.126.183 (195.99.126.183) 48.126 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 5.183 ms
ae2.pcl-cr01.plus.net (195.166.129.6) 4.650 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 4.744 ms
No, the occurrence of this message from the checker has no implications whatsoever on the performance of your router or line. The incorrect information could be likened to the wrong label being attached to the device. It's confusing but doesn't affect the device performance.
Correcting the information requires Plusnet to make what effectively is an administrative change to its "label" in DNS.
David
David
Luzern
Fixes: 9
Quote from: spraxyt
Thanks. Another instance of pcl-bng02 needing DNS updating.
David
May I in ignorance ask, what the effects on internet use and performance of an incorrect rDNS is? Embarrassed
PeeGee
Quote from: lucerne
Quote from: spraxyt
...... the occurrence of this message from the checker has no implications whatsoever on the performance of your router or line. The incorrect information could be likened to the wrong label being attached to the device. It's confusing but doesn't affect the device performance.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
CJC1942
  Posted as requested
peer6-0-10-0-12.telehouse.ukcore.bt.net (62.172.102.25) 2.704 ms
    195.99.126.183 (195.99.126.183) 2.673 ms
    ae1.pcl-cr02.plus.net (195.166.129.3) 2.926 ms
    ae2.pcl-cr01.plus.net (195.166.129.6) 2.566 ms
    link3-central10.pcl-gw01.plus.net (84.93.249.164) 2.659 ms
CJC1942
spraxyt
Resting Legend
Fixes: 75
Thanks, the necessary change to DNS records has been noted. Smiley
David
David
PLan2015
Gateway not identified -
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
peer6-te0-9-0-10.telehouse.ukcore.bt.net (213.121.193.146) 3.320 ms
195.99.126.183 (195.99.126.183) 3.273 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 3.461 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 3.234 ms
spraxyt
Resting Legend
Fixes: 75
Thanks, this has been noted.
David
David
beef68
peer6-te0-0-0-17.telehouse.ukcore.bt.net (109.159.254.140) 4.475 ms
195.99.126.183 (195.99.126.183) 3.037 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 3.124 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 2.999 ms
spraxyt
Resting Legend
Fixes: 75
Thanks. That gateway should be pcl-bng02. The labelling error has been noted.
David
David
redbull2k14
peer6-te0-10-0-20.telehouse.ukcore.bt.net (109.159.254.255) 4.439 ms
195.99.126.183 (195.99.126.183) 19.462 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 12.414 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 4.292 ms
spraxyt
Resting Legend
Fixes: 75
Thanks. The DNS change needed to fix the problem is on the "to do" list.
David
David
beeceegee
Fixes: 5
   ae1.pcl-cr01.plus.net (195.166.129.1) 2.279 ms
   ae2.pcl-cr02.plus.net (195.166.129.7) 5.628 ms
   link3-central10.pcl-gw01.plus.net (84.93.249.164) 2.291 ms
wanting to check the gateway as have noticed on the ping graphs some packet loss last night 8pm-midnight, and looks like the same is happening tonight
spraxyt
Resting Legend
Fixes: 75
That trace shows your gateway is pcl-bng02. Hopefully its DNS entry will be corrected soon.
Packet loss issues are best discussed elsewhere on the forums.
David
David
rongtw
Fixes: 12
i just got another one
    ae2.ptw-cr02.plus.net (195.166.129.5) 25.390 ms
    ae1.pcl-cr02.plus.net (195.166.129.3) 2.700 ms
    link3-central10.pcl-gw01.plus.net (84.93.249.164) 2.709 ms
