Gateway Checker Update
nigel1971
Re: Gateway Checker Update
Mines this.
You are currently connected to gateway pcl-ag03.
bobpullen
Fixes: 330
Quote from: spraxyt
Quote from: rongtw
mmm  Shocked i just got this
Thanks. I think that problem reflects some reassignment of IPs that Plusnet did in January 2015. Plusnet need to change the reverse DNS entries for those IPs. I reported this to Plusnet at the time but it hasn't been actioned.
Everything in this thread seems to point to a single IP/gateway being out of kilter:
~$ host 195.166.130.202
202.130.166.195.in-addr.arpa domain name pointer 202.core.plus.net.
Happy to get it raised internally. Is this thread the only place you reported the issue David?
spraxyt
Resting Legend
Fixes: 75
Quote from: Bob
Happy to get it raised internally. If this thread the only place you reported the issue David?
No, there's a topic with more information (possibly an outbound rDNS issue too) in the UserGroup Technical Focus forum.  I won't post the link here since access is restricted.
David
David
bobpullen
Fixes: 330
I've raised an internal problem and asked for the rDNS entries to be updated (ref: 85652).
For info, I can see three entries in the traceroute here that need updating:
202.core.plus.net [195.166.130.202] <--- This is wrong, should be PTW-BNG02
gi12-1-2-161.pcl-ag01.plus.net [84.93.255.80] < --- This is wrong, should be another PTW-BNG02 hop
lts2.bt622-12.plus.net [212.159.1.194] <--- This is wrong, should be a core gateway hop
frogfoot
Can anyone explain this result (more rDNS errors?)
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Posting the following information as a reply to the Gateway Checker Update topic in the Community Announcements forum will help us to diagnose the problem.
ae2.ptw-cr02.plus.net (195.166.129.5) 7.149 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 3.021 ms
link12-central10.pcl-gw02.plus.net (84.93.249.118) 2.449 ms
Tracing route to bbc.co.uk [212.58.244.18]
over a maximum of 30 hops:
  1    1 ms    <1 ms    <1 ms  192.168.1.1
  2    10 ms    9 ms    9 ms  179.core.plus.net [195.166.130.179]
  3    10 ms    11 ms    9 ms  irb.12.pcl-cr01.plus.net [84.93.249.113]
  4    10 ms    9 ms    9 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  5    10 ms    9 ms    9 ms  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
  6    *        *        *    Request timed out.
  7    *        *        *    Request timed out.
  8    11 ms    9 ms    9 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
  9    11 ms    10 ms    9 ms  132.185.255.149
10    10 ms    9 ms    9 ms  fmt-vip72.telhc.bbc.co.uk [212.58.244.18]
Trace complete.
bobpullen
Fixes: 330
Quote from: frogfoot
These two hops are wrong (should be pcl-bng04):
I'll ask for them to be updated.
bobpullen
Fixes: 330
    In other news...
    Quote from: spraxyt
    • the "not on a Plusnet connection" message suggests action to take if that diagnosis is not correct (see quote 2)
    [quote=1 failed to identify gateway]
    A new range of IP's will be released to the masses shortly - 146.198.0.0/16.
    Do you need to update the script so it recognises these David?
spraxyt
Resting Legend
Fixes: 75
Quote from: Bob
Thanks for the heads up. I've updated the script.
Testing (using a random IP in the range) now gives
IP 146.198.222.18 is a Plusnet IP
Smiley
David
David
Wimpywoo
Hi I've been doing the gateway checker and this came up (page below) is this how it should be please? Thanks
spraxyt
Resting Legend
Fixes: 75
Yes, that output is the correct format. It says your gateway is pcl-ag05.
David
David
Wimpywoo
Thank you so much for your reply. I appreciate very much.
elfish
Gateway IP will not resolve to a hostname.
Which gateway is this?
Which gateway
acc1-10GigE-0-1-0-2.l-far.21cn-ipp.bt.net (109.159.249.20) 2.462 ms
peer2-ae-1.redbus.ukcore.bt.net (195.99.126.97) 2.928 ms
ae1.ptw-cr01.plus.net (195.166.129.0) 11.972 ms
link4-central10.pcl-gw02.plus.net (84.93.249.38) 4.643 ms
spraxyt
Resting Legend
Fixes: 75
Thanks.
It looks like Plusnet need to change the rDNS entry for 84.93.249.38 to reflect that it is now a gateway. Smiley
I assume this results from the capacity increases made yesterday morning.
David
David
bobpullen
Fixes: 330
It's ptn-bng02.
I'll have somebody look at the rDNS again (ref: 85652) Roll_eyes
PeeGee
Just got the following response (after reloaing the router with an old configuration):
   peer6-te0-0-0-17.telehouse.ukcore.bt.net (109.159.254.140) 3.970 ms
   195.99.126.183 (195.99.126.183) 2.654 ms
   ae1.pcl-cr02.plus.net (195.166.129.3) 2.931 ms
   link3-central10.pcl-gw01.plus.net (84.93.249.164) 4.050 ms
Phil
corrected the "end quote" Embarrassed
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
