Gateway Checker Update
- News & Announcements
- Community Announcements
- Re: Gateway Checker Update
13-01-2015 1:37 PM
13-01-2015 1:42 PM
13-01-2015 6:40 PM
[tt]traceroute to 195.166.130.202 (195.166.130.202), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 1.366 ms
2 lo0-central10.pcl-ag07.plus.net (195.166.128.188) 20.172 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.184) 19.977 ms
4 xe-9-0-0.pcl-cr01.plus.net (212.159.0.216) 21.708 ms
5 ae1.ptw-cr01.plus.net (195.166.129.0) 19.646 ms
6 lts5.bt622-12.plus.net (212.159.1.197) 19.921 ms
7 202.core.plus.net (195.166.130.202) 21.384 ms
traceroute to 195.166.130.201 (195.166.130.201), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 12.865 ms
2 lo0-central10.pcl-ag07.plus.net (195.166.128.188) 29.723 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.184) 56.698 ms
4 xe-9-0-0.pcl-cr01.plus.net (212.159.0.216) 20.407 ms
5 ae1.ptw-cr01.plus.net (195.166.129.0) 38.759 ms
6 po2.ptw-gw01.plus.net (195.166.129.37) 19.234 ms
7 lo0.default.ptw-bng02.plus.net (195.166.130.201) 21.526 ms
traceroute to 195.166.128.182 (195.166.128.182), 30 hops max, 60 byte packets
1 192.168.0.1 (192.168.0.1) 1.359 ms
2 lo0-central10.pcl-ag07.plus.net (195.166.128.188) 42.907 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.184) 20.225 ms
4 xe-9-0-0.pcl-cr01.plus.net (212.159.0.216) 20.366 ms
5 po2.pcl-gw01.plus.net (195.166.129.41) 32.152 ms
6 lo0-central10.pcl-ag01.plus.net (195.166.128.182) 21.354 ms[/tt]
13-01-2015 11:21 PM
>tracert 195.166.130.202
Tracing route to 202.core.plus.net [195.166.130.202]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
2 34 ms 36 ms 38 ms lo0-central10.ptn-ag02.plus.net [195.166.128.191]
3 34 ms 33 ms 33 ms link-a-central10.ptn-gw01.plus.net [212.159.2.132]
4 34 ms 33 ms 33 ms xe-1-2-0.ptw-cr01.plus.net [212.159.0.112]
5 35 ms 33 ms 34 ms lts1.bt622-12.plus.net [212.159.1.193]
6 34 ms 33 ms 33 ms 202.core.plus.net [195.166.130.202]
tracert to 195.166.130.200 & also to 201 & 203 all resolve to ptw-bng02
11-04-2015 8:13 PM
11-04-2015 9:20 PM
11-04-2015 9:59 PM
e.g. tracert bbc.co.uk
11-04-2015 11:24 PM
Quote from: rongtw mmm i just got this
Thanks. I think that problem reflects some reassignment of IPs that Plusnet did in January 2015. Plusnet need to change the reverse DNS entries for those IPs. I reported this to Plusnet at the time but it hasn't been actioned.
David
12-04-2015 12:23 AM
Quote from: AndyH I think there is something wrong with your account (unless that is a new gateway) and this might explain your problems.
This has to be one of the most stupid suggestions I've seen posted on here in a long time!
12-04-2015 12:44 AM
12-04-2015 1:19 AM
Quote from: jelv This has to be one of the most stupid suggestions I've seen posted on here in a long time!
I take offence at this comment.
The reason I made my statement was:
1) rongtw is seeing an issue of packet loss/high latency to some addresses and not others (latency/packet loss only seem to be an issue on the connection from him rather than to him). This is consistent with an account issue that someone else had a little while ago and the same Plusnet did the same dial in test (which came back ok). Every single trace route he's posted, is to a lo0-central.x address and there are at least 5 different ones he's posted.
2) The second hop IP on his latest trace route does not appear to be consistent with any of the IPs already flagged up as having incorrect rDNS.
I did also say that it might be a new gateway, but in view of rongtw's problems, I looked at another possible cause.
12-04-2015 1:29 AM
Quote from: AndyH I take offence at this comment.
Well it's a good job you didn't see any of the first four drafts before I toned it down to that!
12-04-2015 2:31 AM
to suggest its a broken account is baffling and I see nothing wrong with jelv's comment.
19-04-2015 1:59 PM
19-04-2015 2:33 PM
