site blocking
Ianh64
site blocking
Hi can anyone help blocking pornography sites keeps getting switched on despite turning it off in safeguarding area.
is this a new plusnet policy
19 REPLIES 19
Fixes: 337
Re: site blocking
I sincerely doubt it - have you got computer-literate youngsters?
Ianh64
Re: site blocking
no just me in house
Fixes: 337
Re: site blocking
OK. I seem to recall a couple of similar queries recently, and I thought the issue had been resolved.
@Townman  / @MisterW  - any clues?
RobPN
Fixes: 13
Re: site blocking
I started typing a reply to the OP @jab1 but then I re-read the post.
ICBW, but due to the lack of punctuation I initially thought the same as I think you did, i.e. that the OP wanted to block porn, but I then realised s/he might want to access porn sites and is enquiring why the blocking is happening.
Fixes: 337
Re: site blocking
Having re-read the OP, @RobPN , I see what you mean - clarification from @Ianh64  is needed.
Fixes: 239
Re: site blocking
There are two levels of blocking - user selected by setting parental / content control (somewhere in the user portal / member centre) and generic BT blocking to very unsavoury content.
RealAleMadrid
Fixes: 67
Re: site blocking
@Ianh64  Your opening post is very unclear, it suggests that could be using Plusnet safeguard, which you probably don't want or need. So try disabling that and see if you can access the sites you are having trouble with, however as @Townman has said there could be other higher level blocking going on.
Ianh64
Re: site blocking
Aplogies poor grammar. I do want to watch porn.
And before a few days ago was able. I have not changed any settings but when I look at safeguarding it is off however when I look at the blocked subjects list porn is blocked I switch that off go away and when I return it’s back on again
Fixes: 239
Re: site blocking
Safeguarding is implemented by changing the DNS servers assigned to the router. If safeguarding is getting switched on again then you would have seen a change of DNS servers. What are the DNS servers your router is using?
Ianh64
Re: site blocking
Absolutely no
Idea re dns servers how do I find out
Fixes: 239
Re: site blocking
Look at the router administration page. The connection status will show the DNS servers assigned.
Fixes: 460
Re: site blocking
@Townman
Unless of course the Plusnet DNS servers are being over-ridden in the device settings. Maybe a third party block?.
Ianh64
Re: site blocking
thanks my dns is below cant work out how to change it and not sure i should
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.13.49
Fixes: 239
Re: site blocking
@Ianh64
They are the standard DNS servers, not the safeguarding DNS servers.  Therefore as @Baldrick1 hinted, you must have some other safeguarding service on your device ... possibly AV software or other safe surfing technology ... OR what you are trying to look at has some higher 'authority' block.
