site blocking
Ianh64
Re: site blocking
its def plus net i can acess sites via phone  etc and its across multiple devices and browsers
eg is i disconnect lap top from plus net and join via my non plus net phone its fine.
Its the grab below it just will not switch off
Fixes: 334
Re: site blocking
Purely as an aside, @Ianh64 , I wouldn't publicly state I wanted to watch porn.
Ianh64
Re: site blocking
If I can’t fix this I will leave Plusnet
Fixes: 124
Re: site blocking
I've never used SafeGuard, I see the same as you
Have you thought of enabling SafeGuard but not setting up any blocks, removing the current blocks?
Maybe considering using a VPN, that way the sites you visit won't know you're a plusnet customer by your IP Address
Fixes: 236
Re: site blocking
“keeps getting switched on despite turning it off in safeguarding area”
What are you turning off and where?
Plusnet safe guarding is not turned on by default and the reported DNS servers are not the safe guarding DNS servers.
