Unreliable Internet and cancellation without fees
alan1993
I'm currently on month 5 of my 24-month broadband contract, and I would like to leave Plusnet. My internet connection is unreliable and keeps disconnecting frequently. The router often switches to red, indicating no connection at all, which makes it very frustrating, especially as someone who works from home.
Additionally, the internet speed is unacceptably slow. In my contract the upload speed is specified as 1Mbps, which is already quite low, but in reality, it is always below that. When I try to upload even small attachments to emails, it takes an incredibly long time, and during that time, I cannot browse any websites or use the internet for anything else.
In 2024, this kind of performance is simply not acceptable. I rely on a stable and fast connection for my work, but the service I'm receiving from is preventing me from being able to work effectively. It's severely impacting my productivity.
Can anyone support please what steps I can take to get this resolved?
17 REPLIES 17
Fixes: 334
Re: Unreliable Internet and cancellations without fees
Your description seems to indicate that there are problems, most likely between the OpenReach network and you. What product are you on - FTTC?
alan1993
Hi John,
Not sure what FTTC is, but according to my online account is "Unlimited Broadband inc. Line rental". Thanks!
Fixes: 334
OK - you are on FTTC. Please try and follow the below, and then we (the Community) may be able to advise.
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. - if it will run. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
Fixes: 526
@jab1 I think that's actually ADSL
That would explain the 1Mb max upstream speed and it may possibly be capped at lower.
If that's the case then uploading any amount will saturate the upstream bandwidth and thus affect downloading.
Fixes: 334
Ooops, my error, @MisterW , sincere apologies. The info I requested though would still be helpful?
Fixes: 526
It would. It will show if the upstream is capped
Fixes: 334
And hopefully, if there are connection issues.
alan1993
Thanks for the support! Just had a call with the customer service and according the them upload speed of 0.1-1mbs is "normal". They clearly don't care that the connection is not existent and they advised my that there is nothing they can do and I should make a peace with that. Anyways the only solution would be paying extreme cancellation fee.
Fixes: 334
@alan1993 As @MisterW  pointed out, I misread your 'package' - sorrty, but if you could provide the information requested, there are those on here who can give you somewhat less 'take it or leave it' advice, which is effectively what CS are saying.
markhawkin
All Star
Fixes: 18
@alan1993
If you were released from your Plusnet contract what would you do instead for Internet access?
Other suppliers using the Openreach (phone) network would have the same problem as it sounds like you are on a long copper line some miles from the serving exchange with no fibre to the cabinet or full fibre option.
Does someone else (Virgin Media perhaps) offer an alternative?
Is mobile phone network based data a possibility?
If it comes to it Starlink might be worth considering.
I assume you have recently moved to this location.
What options do you get for your postcode from https://bidb.uk/ ?
alan1993
Hi there, thanks for your reply. So just briefly answering your question - I moved to the building about 5 months ago and upon checking with different providers Plusnet was only option. With that said, as I'm working from home I didn't have much choice, so I went for it. (if I knew back then how bad the connection would be I would probably go with some mobile broadband option - I had in the past and it was much better than what I have now.)
I was keep checking for alternatives and find out that about a month ago Virgin started to offer Fibre Brodband in my building with the speed hundreds times better compared to Plusnet. I checked with Plusnet if they could possibly upgrade my connection (I'm willing to pay more, just to have reliable connection), unfortunately they said that the deal I have it's the best option in my area.
I checked the link you provided and indeed I could possibly go with Virgin Mobile or Community Fibre.
SammyM
Fixes: 101
Re: Unreliable Internet and cancellation without fees
Hiya @alan1993
I can see you called yesterday after your post and an agent helped with this.
Please let us know if you need anything else.
 Sammy M - Sheffield Team
markhawkin
All Star
Fixes: 18
@alan1993
On the assumption that Openreach full fibre isn't available (and won't be shortly), of the two options you list, personally I would recommend Community Fibre.
It doesn't sould like you are in a rural area on a long line, so ADSL being your only choice with a low speed is a bit of a puzzle.
For working at home more or less any Community Fibre package would suffice (there are some "secret" low speed packages on 12 month contracts that don't appear on their front page) and if they offer service I might take it whether or not you can end the Plusnet 1Mb/s line.
Fixes: 87
@alan1993
As previously requested if you provide a screen image from the following (after hiding your details) then we can advise on what's available via the OpenReach network.
You could also look at the OR website to see if there are any plans for FTTP in your area - www.openreach.com
