new charges for exceeding monthly allowance?
- Re: new charges for exceeding monthly allowance?
10-03-2009 5:08 PM
Quote It seems that that isn't the only thing that needs fixing - on the Set a price limit page - (my bold)
"You may be charged slightly more than your limit, if the money remaining before reaching your limit is less than the minimum £2 charge for additional usage. "
So what exactly does that mean?
And...........
10-03-2009 5:17 PM
10-03-2009 10:48 PM
Hope that's clear,
Bertb
11-03-2009 10:06 AM
You're absolutely correct on all counts
11-03-2009 10:11 AM
Bertb
11-03-2009 3:47 PM
maybe I'm just being a bit thick today, also perhaps I should have just bolded the words after
Quote the minimum £2 charge for additional usage.
So how can one buy a single 1G @98p pre-pay/£1.22 post pay (option 1) if there's a minimum charge of £2?
11-03-2009 3:51 PM
The same way that you were always able to do so.
Like I say, it's just a misdirected email. The functionality of purchasing additional single gigabytes of usage allowance should not have changed for Broadband Your Way customers.
11-03-2009 5:18 PM
Quote that isn't the only thing that needs fixing - on the Set a price limit page - (my bold)
19-03-2009 2:44 AM
19-03-2009 10:30 AM
Do me a favour and try setting it to £11.
Just to see if it works.
19-03-2009 10:33 AM
21-03-2009 7:42 AM
Make what you will of the first screenshot, i don't know what may happen. (The implication is you can buy a fraction of a GB or has that always been the case?)
The second screen shot is possibly more likely to give the desired result
15-04-2009 10:27 AM
I'm still getting the same "We've added a further 2 GB of usage for the month to your account, which will add a £2 charge to your next subscription charge.
" in my usage allowance mail however, the billing amount is correct at:
1GB Additional Data Transfer Charge Until DATE £1.06 £0.16 £1.22
I'll be watching you though!
15-04-2009 9:04 PM
You have caused great confusion with one of my referrals. His view of Plusnet is dropping rapidly. Don't you care?
15-04-2009 10:37 PM
