Very slow almost unusable
stathe
Last couple of days my broadband has declined to a very low speed Has plusnet done something to my link ?Huh
16 REPLIES 16
pvmb
Champion
Fixes: 16
Re: Very slow almost unusable
Nobody can answer that without basic information:
What BB are you on? (ADSL, FTTC, FTTP)
What are your current speeds?
What are they supposed to be?
Have you a phone line?
Have you tested your landline for noise using a phone?
etc.
SammyM
Fixes: 101
Hiya @stathe
I'm sorry you are having issues with your connection and for the hassle it will be causing.  My tests are not flagging anything, can you tell me what speed you are receiving?
 Sammy M - Sheffield Team
stathe
Says 1.6 or !.7 hoped for 2 but am a few miles from Burrowbridge and have to switch off and on to get this Thank you I am 88 and need a wiredr phone am rather inclined to think Plusnet  are robbing me
pvmb
Champion
Fixes: 16
Still no useable information!
Is there anyone else available your end who can help out?
WRT "wired phone", all landlines are going to be turned off nationally - not just Plusnet ones. Why exactly do you need such a phone? If you want an easy transition to a home phone then, when the landline is due to be cancelled, you could ask Plusnet to transfer you, without exit fees, to EE and then BT would  arrange for you to have a 'home phone' via their 'Digital Voice' system.
There are though some potential 'issues' with digital home phones.
stathe
I seem to be at the edge of Burrowbridge and elderly I need my,Plusnet e mail as I have a large number of important things on it and it will be a burden to change them all  We have wires up  BB not operative   but I will hang on until the end and am told that nothing will be done for a year or so
stathe
This is a quick overview of your Plusnet Hub's status.
Connection status:
Connection type:
Broadband (DSL)
Downstream sync speed:
2.191 Mbps
Upstream sync speed:
779 Kbps
Network uptime:
2 Days 23 Hrs 54 Mins
Broadband IP address:
81.174.133.160
Default gateway:
195.166.130.255
Primary DNS:
212.159.13.49
Secondary DNS:
212.159.6.9
System uptime:
2 Days 23 Hrs 57 Mins
Serial number:
+108417+2237017087
Firmware version:
v0.10.00.04201-PN
Firmware updated:
30-Jun-2023
Moderator's note by Mike (Mav): Something in the HTML was messing the page.
pvmb
Champion
Fixes: 16
Thanks, stathe. So you are on ADSL (unsurprisingly) and we know you have a landline phone.
Those speeds look low! You are either on the end of a very long telephone line, or there is a fault. Have the speeds always been this low, or is this something recent? What speeds are you supposed to be getting with your contract, do you know?
Have you checked your BT circuit? Here: https://www.broadbandchecker.btwholesale.com
Also, you can see in your router what the current figures are for Noise margin and Line attenuation. You will have to log in to your router using the router Admin password to see this. Your router looks to me as if it coud be a Plusnet Hub 2, in which case these figures are found at: Advanced settings/Technical log
e.g. In my case (on 40/10 FTTC) these show as:
Data rate: 9.999 Mbps / 40 Mbps
Maximum data rate: 23.153 Mbps / 72.939 Mbps
Noise margin: 14.5 / 15.2
Line attenuation: 7.1 / 13.5
Signal attenuation: 7.0 / 15.2
This should help to decide if you are just unlucky in having a very long landline or there is indeed a problem.
Also, as you have a landline phone, have you checked for noise on your landline? Just dial 17070 and Option 2 for the BT Quiet Line Test. You should not be able to hear any significant hissing or any crackling during the quiet periods.
If there is, I suggest - if you do have a mobile phone - texting: "PHONE <your landline number>"
to number 61998 for the Plusnet automatic Line Test and reporting system.
Problem: Plusnet Report A Problem | Help | Plusnet
Burrowbridge: Burrowbridge Telephone Exchange. Network ID (WWBURR) (telephone-exchange.co.uk)
pvmb
Champion
Fixes: 16
@pvmb wrote:
If there is, I suggest - if you do have a mobile phone - texting: "PHONE <your landline number>" to number 61998 for the Plusnet automatic Line Test and reporting system.
CORRECTION!
My description above is for the BT automatic Line Test, rather than the Plusnet one. (Mind you, when I used it a few years ago it still worked as it recognised the line was a Plusnet phone and redirected to the Plusnet bot.)
It should have been text: "Phone <your landline number>"  to number 07800 008121 as per the "Problem" link shown above.
stathe
Thank you I will try again lateras it is probably as good as it gets when I switch
Fixes: 251
Ref post #7 - we need to see the stats from the ADVANCED section please.  The home page summary does not show the SNRM.
stathe
Event log
This is a list of your Plusnet Hub settings and current statistics.
Product code:Plusnet Hub Two
Serial number:+108417+2237017087
Firmware version:v0.10.00.04201-PN
Firmware updated:30-Jun-2023
Board version:R01
GUI version:1.9 16_08_2022
DSL uptime:5 Days 5 Hrs 44 Mins
Data rate:779 Kbps / 2.191 Mbps
Maximum data rate:833 Kbps / 2.564 Mbps
Noise margin:6.4 / 4.4
Line attenuation:44.3 / 71.0
Signal attenuation:43.2 / 74.0
VPI/VCI:0/38
Modulation:G.992.5(ADSL2+)
Latency type:Interleaved
Upstream error control:Off
Downstream error control:Off
Data sent / received:1.4 GB Uploaded / 10.4 GB Downloaded
Broadband username:[email protected]
2.4 GHz wireless network name:PLUSNET-37C9RX
2.4 GHz wireless channel:Smart (Channel 1)
5 GHz wireless network name:PLUSNET-37C9RX
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:AC:B6:87:9D:6F:FD
Software variant:-
Boot loader:0.1.7-PN (Thu Nov 30 09:45:22 2017)
stathe
Is this it ?
pvmb
Champion
Fixes: 16
Yes it is stathe, thanks.
Line attenuation: 44.3 / 71.0
Signal attenuation: 43.2 / 74.0
Ye Gods! Unless there is something wrong somewhere you must be on the end of a very long phone line. (> 3 miles?)
The SNR figures, along with the DSL uptime, don't seem to me to indicate anything is actually going wrong with your BB.
DSL uptime: 5 Days 5 Hrs 44 Mins
Noise margin: 6.4 / 4.4
So I don't know what to suggest. Perhaps you will just need to put up with it until full fibre (FTTP) arrives. You could try to go for an existing fibre product (FTTC) instead of your ADSL broadband. Unfortunately I understand if you do that now you would have to lose your landline (which you will eventually, anyway). So it's a question of what is most important to you. Perhaps somebody else here knows better?
Has your speed dropped to this level recently or was it always so slow? Only other things I can think of is if you can get BB wirelessly via smartphone or suchlike.
Fixes: 251
Ouch! At that line length (attenuation) it is surprising that you’ve got the speed as good as it is. You must be very rural.
You are limited by the physics of long copper circuits - for faster speeds you need to change products as described above.
