Constant Dropouts
DerekW
Constant Dropouts
I have been having constant drop outs all day and it is really frustrating.
Is PlusNet having issues today in the Livingston area?
Can someone from the PlusNet tech team look into this for me please.
On a side note, when I could actually get online and log into my account I also noticed that my account had changed to show me different download/upload speeds - They are not the same as I contracted for almost 2 years ago.
"No one has ever become poor by giving" - Anne Frank
18 REPLIES 18
Fixes: 387
Re: Constant Dropouts
@DerekW Which router do you have, and, irrespective of that, can you post the detail found on the relevant pages signposted to below?
For the Hub One -
For the Hub Two -
DerekW
I am using the TP Archer VR2800 as my router.
Log attached
Fixes: 250
Each reconnection is at a slower speed.  Sight of the router connection stats (not the diagnostic log) would be helpful please.
Is this FTTC or SOGEA?
If FTTC, is the phone line free of noise?
Fixes: 387
Thanks for that, @DerekW it confirms what I thought - you are suffering xDSL drops, most likely due to an issue in the Openreach network.
Can you please follow the below:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one the only option is to call Plusnet - 0330 123 9123
Fixes: 387
Cheers @Townman  - should have asked for that as well.
DerekW
My connection is FTTC
Unfortunately I do have a telephone to test the line with - I have always use a mobile for calls, I could try and source one from somewhere not sure when though.
Have attached screen shot of additional information.
Fixes: 387
@DerekW A basic phone is a very useful tool on an FTTC connection, but looking at your latest post, I suggest reporting a broadband fault as shown in my previous post.
DerekW
Many thanks, will report a fault
Think I will also invest in a corded phone
Fixes: 387
Dead cheap these days - if you can find them. Mine came from Argos for ~£6.00, don't know what they are now.
RealAleMadrid
Fixes: 68
@DerekW  I wouldn't bother if I were you, the copper landline phone service (PSTN) is being withdrawn for the majority of lines at the end of 2025 so a phone will no longer be a useful testing tool.
Fixes: 387
Not the 2027 I keep reading, @RealAleMadrid ? Although, as even BT/OR can't make their minds up...
DerekW
The Plusnet bot said: The line from the network to your home appears to be performing well.
Next it wanted to refresh the connection to my "hub"
Followed 5 min later  by can I restart my router manually (I knew this request would be incoming)
Having restarted things "seem" to be back to normal on connection status page.
Fixes: 387
Keep your eyes on that screen, Derek - from what I saw in the error log, I'm not totally convinced that has fixed it - but I could be wrong.
DerekW
Will do
Thanks for your help
