Upload speeds today 6 December
broadbob
Am on a Manchester exchange
Download speed profile reasonably stable at approx 4000 kbps
However upload profile speed has dropped today from long term approx 600 kbps to 288 kbps.
BT speedtester today giving actual 228 Kbps
Any one else seen this?
18 REPLIES 18
jojopillo
Re: Upload speeds today 6 December
HI broadbob,
Are you able to plug into your test socket so that we can rule out any internal issues?
Jojo Smiley
broadbob
Hi Jojo
Thanks for your speedy reply
Can do but very doubtful if my wiring is at fault.
The man from BT has already been
Will try to see what happens if I simply re boot the router
Was trying to avoid this as I am on a learning period.
Will let you know the result in due course
broadbob
Hi Jojo
Following my last post, I have rebooted the router which is still plugged into the usual socket, not the master socket.
The Upstream profile has risen to 608 kbps - actual speed 482 kbps
Downstream profile / rate virtually unchanged (3726/ 2672 Kbps)
So it looks like it was hopefully a glitch on my line not a general problem.
Now a matter of wait and see what happens during the new learning period.
Regards
jojopillo
Hi broadbob,
If you're happy with that then that's ok. However, if you do try the test socket it may reveal an issue with internal wiring.
Jojo Smiley
broadbob
Dear Jojo
Thanks for your reply. As I said I'll wait to see what develops. The number of disconnections is no worse on the current phone socket is no worse than it was whilst connected to the mastersocket.
I realise that this may not be the right place to raise this subject, but whilst on upload speeds, I assist someone who has a newly replaced Plusnet Thomson 585 v8 router. This, like the old v8 one, gives an upload speed when on a wireless connnection of about 50% of the speed when wired.
The user can live with this situation as it is not a real problem, but out of interest, is a solution save changing to a v7 router in sight?
adamwalker
Fixes: 221
A firmware update may help with that, we can usually trigger those remotely if needed.
 Adam Walker
broadbob
Hi Adam
Firstly
The upload speed problem I had yesterday seems to be solved. It has been stable and at expected level since reboot yesterday pm.
Secondly
The Thomson v8 router is not mine, it is at the house of someone I assist.
The router was a replacement and is very new. I would have thought it had the most up to date firmware already.
What version do you propose?
If it is different to the one already installed and the user decides to change, they will be in touch directly via PlusNet Help and Support.
I presume this is the best route for them.
jojopillo
HI broadbob,
If the user runs a speed test via ethernet and then via wireless to compare the upload speeds we can look into rectifying this for them.
Jojo Smiley
broadbob
Hi Jojo
Thanks for your last message
The speed tests which have been run on mybroadbandspeed.co.uk using 2 laptops and a desktop are attached
You will see that the router details are
Thomson Router TG585 v 8 running firmware 8.2.7.8
Smiley
jojopillo
HI broadbob,
Tell them to raise a ticket for my attention and I'll send them a replacement router. If you can then give me the ticket number I'll be able to pick it up quicker.
Jojo Smiley
broadbob
Dear Jojo
Thanks for your mesage.
As requested a ticket has been raised from the users account with the support desk marked for your attention
Reference is 49697578
Thanks for your help with this and also my own upload problem.
Regards
Smiley
jojopillo
HI broadbob,
I've done that and replied to her ticket.
Jojo Smiley
broadbob
Hi Jojo
Router received - many thanks
Since your last post, it could be that the user has been converted to 21CN.
I have posted an update on behalf of the user on ticket 49697578 asking for advice.
Look forward to your comments
Broadbob
Smiley
jojopillo
Hi broadbob,
I've replied to the ticket now.
Jojo Smiley
