Upload speeds today 6 December
- Re: Upload speeds today 6 December
06-12-2011 2:29 PM
Download speed profile reasonably stable at approx 4000 kbps
However upload profile speed has dropped today from long term approx 600 kbps to 288 kbps.
BT speedtester today giving actual 228 Kbps
Any one else seen this?
06-12-2011 2:54 PM
Are you able to plug into your test socket so that we can rule out any internal issues?
Jojo
06-12-2011 3:31 PM
Thanks for your speedy reply
Can do but very doubtful if my wiring is at fault.
The man from BT has already been
Will try to see what happens if I simply re boot the router
Was trying to avoid this as I am on a learning period.
Will let you know the result in due course
06-12-2011 4:19 PM
Following my last post, I have rebooted the router which is still plugged into the usual socket, not the master socket.
The Upstream profile has risen to 608 kbps - actual speed 482 kbps
Downstream profile / rate virtually unchanged (3726/ 2672 Kbps)
So it looks like it was hopefully a glitch on my line not a general problem.
Now a matter of wait and see what happens during the new learning period.
Regards
06-12-2011 4:57 PM
If you're happy with that then that's ok. However, if you do try the test socket it may reveal an issue with internal wiring.
Jojo
06-12-2011 5:53 PM
Thanks for your reply. As I said I'll wait to see what develops. The number of disconnections is no worse on the current phone socket is no worse than it was whilst connected to the mastersocket.
I realise that this may not be the right place to raise this subject, but whilst on upload speeds, I assist someone who has a newly replaced Plusnet Thomson 585 v8 router. This, like the old v8 one, gives an upload speed when on a wireless connnection of about 50% of the speed when wired.
The user can live with this situation as it is not a real problem, but out of interest, is a solution save changing to a v7 router in sight?
07-12-2011 9:42 AM
07-12-2011 12:37 PM
Firstly
The upload speed problem I had yesterday seems to be solved. It has been stable and at expected level since reboot yesterday pm.
Secondly
The Thomson v8 router is not mine, it is at the house of someone I assist.
The router was a replacement and is very new. I would have thought it had the most up to date firmware already.
What version do you propose?
If it is different to the one already installed and the user decides to change, they will be in touch directly via PlusNet Help and Support.
I presume this is the best route for them.
07-12-2011 2:13 PM
If the user runs a speed test via ethernet and then via wireless to compare the upload speeds we can look into rectifying this for them.
Jojo
08-12-2011 9:27 AM
Thanks for your last message
The speed tests which have been run on mybroadbandspeed.co.uk using 2 laptops and a desktop are attached
You will see that the router details are
Thomson Router TG585 v 8 running firmware 8.2.7.8
08-12-2011 11:43 AM
Tell them to raise a ticket for my attention and I'll send them a replacement router. If you can then give me the ticket number I'll be able to pick it up quicker.
Jojo
09-12-2011 11:16 AM
Thanks for your mesage.
As requested a ticket has been raised from the users account with the support desk marked for your attention
Reference is 49697578
Thanks for your help with this and also my own upload problem.
Regards
09-12-2011 1:22 PM
I've done that and replied to her ticket.
Jojo
16-12-2011 7:32 AM
Router received - many thanks
Since your last post, it could be that the user has been converted to 21CN.
I have posted an update on behalf of the user on ticket 49697578 asking for advice.
Look forward to your comments
Broadbob
16-12-2011 9:30 AM
I've replied to the ticket now.
Jojo
