Trinitarian broadband!!!
Fixes: 162
Re: Trinitarian broadband!!!
Hi Avodat,
A note of caution / late breaking news - please see http://www.plus.net/supportpages.html?a=2&support_action=messages&ispservice_id=adsldial
There were last night and are today widespread issues (apparently BT related) impacting many users across many ISPs up and down the country causing users to be disconnected from the internet.  Given we are watching your link for connectivity issues, I thought you should be made aware of this wide spread issue.
In doing so I'm mindful to make sure you understand the devil-in-the-detail of what we are doing and looking for, as there are two types of disconnections - one at DSL (synch) level (which also kills PPP) and one not involving DSL, but just PPP.
RouterStats will ONLY identify DSL disconnects, not PPP alone disconnects (though with a simple fiddle it could)
The above BT failures will only involve PPP.
Whatever to you the issue will be the same - you loose internet connectivity, however the diagnostic conclusions are different.  When you are able, the router logs via RouterStats will show the devilish detail we need.
Kevin
avodat
All has been quiet thus far, but I don't really expect a problem today - it will probably be tomorrow if it is going to happen. Maybe Anotherone's remedial action has resolved the issue  Cool
Fixes: 162
Quote from: avodat
If you mean the target SNRM adjustment, then that was done by Adam of PlusNet - Anotherone and I are mere customers, with the ability to do nothing other than offer guidance to others.
If that does mitigate the issue, you could decide to leave this as it is and accept the sacrifice in speed, or we could look at getting other things sorted too.
Anotherone
Champion
Fixes: 21
I think he meant the factory reset, but the SNRM Target adjustment may also be of some help.
The log is no doubt getting overfull with garbage such as
FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 120.4.102.122 Dst ip: 87.114.xxx.xxx  Type: Destination Unreachable Code: Port Unreacheable
and especially
Aug 23 16:22:27 SNTP Synchronised again to server: 212.159.6.9
Fixes: 162
Embarrassed Embarrassed Sorry!  I'd forgotten about that one!  may be we should put a list in here of things done which could have a bearing on facilitating improvements...
1. 2014-08-22 Factory reset on TG582n @firmware 8.4.4.J
2. 2014-08-22 Target SNRM set to 6dB (15:05) as per post #41 firewall log content
Anotherone
Champion
Fixes: 21
Kevin, you can edit your last post, just done a quick review of the thread and in https://community.plus.net/forum/index.php/topic,130792.msg1141173.html#msg1141173
Info    Aug 22 15:05:00   xDSL linestate down
nfo    Aug 22 15:06:22   xDSL linestate up (ITU-T G.992.5; downstream: 13483 kbit/s, upstream: 1235 kbit/s; output Power Down: 20.8 dBm, Up: 12.3 dBm; line Attenuation Down: 22.5 dB, Up: 10.9 dB; snr Margin Down: 6.1 dB, Up: 6.6 dB)
And there was me saying in the next post "What's above in isolation is not that eventful really"  Roll_eyes Embarrassed
So it looks like it happened yesterday at 1505 Wink
Apologies for not spotting it before.
Firewall logs can be useful as well as stats (hint)  Smiley
avodat
Telnet log (log in ID redacted):
syslog msgbuf show hist=enabled
<173> Aug 22 15:05:00 xDSL linestate down
<85> Aug 22 15:05:00 FIREWALL event (1 of 1): created rules
<85> Aug 22 15:05:00 FIREWALL event (1 of 1): modified rules
<173> Aug 22 15:05:17 xDSL linestate down
<173> Aug 22 15:05:48 xDSL linestate down
<132> Aug 22 15:05:51 PPP link down (Internet) [146.90.194.206]
<173> Aug 22 15:06:22 xDSL linestate up (ITU-T G.992.5; downstream: 13483 kbit/s, upstream: 1235 kbit/s; output Power Down: 20.8 dBm, Up: 12.3 dBm; line Attenuation Down: 22.5 dB, Up: 10.9 dB; snr Margin Down: 6.1 dB, Up: 6.6 dB)
<39> Aug 22 15:06:29 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<39> Aug 22 15:06:32 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Aug 22 15:06:38 PPP CHAP Chap receive success : authentication ok
<132> Aug 22 15:06:44 PPP link up (Internet) [84.93.214.]
<85> Aug 22 15:06:45 FIREWALL event (1 of 1): deleted rules
<14> Aug 22 15:06:54 CONFIGURATION saved by TR69
<102> Aug 22 15:07:20 SNTP Synchronised to server: 212.159.6.10
<81> Aug 22 15:21:20 FIREWALL icmp check (1 of 6): Protocol: ICMP  Src ip: 110.243.206.56 Dst ip: 84.93.214.184 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 22 15:23:57 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 76.2.126.147 Dst ip: 84.93.214.184 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 22 15:51:41 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 109.161.143.221 Dst ip: 84.93.214.184 Type: Destination Unreachable Code: Port Unreacheable
<37> Aug 22 16:03:21 LOGIN User logged in on [HTTP] (from 192.168.1.  )
<81> Aug 22 16:05:37 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 36.48.211.18 Dst ip: 84.93.214.184 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 22 16:07:20 SNTP Synchronised to server: 212.159.13.50
<37> Aug 22 16:16:18 LOGIN User tried to login on [HTTP] (from 192.168.1.  )
<37> Aug 22 16:17:13 LOGIN User logged in on [HTTP] (from 192.168.1.  )
<37> Aug 22 16:53:33 LOGIN User logged in on [HTTP] (from 192.168.1.  )
<102> Aug 22 17:07:20 SNTP Synchronised to server: 212.159.6.10
<81> Aug 22 17:30:19 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 61.102.35.117 Dst ip: 84.93.214.184 Type: Destination Unreachable Code: Port Unreacheable
<173> Aug 22 18:07:27 xDSL linestate down
<85> Aug 22 18:07:28 FIREWALL event (1 of 1): created rules
<85> Aug 22 18:07:28 FIREWALL event (1 of 1): modified rules
<173> Aug 22 18:07:58 xDSL linestate down
<132> Aug 22 18:08:13 PPP link down (Internet) [84.93.214.]
<100> Aug 22 18:08:15 SNTP Unable to contact server: 198.18.1.16
<173> Aug 22 18:08:29 xDSL linestate down
<173> Aug 22 18:08:56 xDSL linestate up (ITU-T G.992.5; downstream: 13439 kbit/s, upstream: 1231 kbit/s; output Power Down: 20.8 dBm, Up: 12.4 dBm; line Attenuation Down: 22.5 dB, Up: 10.9 dB; snr Margin Down: 6.1 dB, Up: 6.5 dB)
<39> Aug 22 18:09:09 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<39> Aug 22 18:09:13 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Aug 22 18:09:14 PPP CHAP Chap receive success : authentication ok
<132> Aug 22 18:09:18 PPP link up (Internet) [80.189.81.]
<85> Aug 22 18:09:19 FIREWALL event (1 of 1): deleted rules
<14> Aug 22 18:09:32 CONFIGURATION saved by TR69
<81> Aug 22 18:29:18 FIREWALL replay check (1 of 1): Protocol: ICMP  Src ip: 86.128.221.89 Dst ip: 80.189.81.160 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 22 18:46:01 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 202.177.65.170 Dst ip: 80.189.81.160 Type: Destination Unreachable Code: Communication Administratively Prohibited
<102> Aug 22 19:08:15 SNTP Synchronised to server: 212.159.6.9
<81> Aug 22 19:54:32 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 37.14.245.218 Dst ip: 80.189.81.160 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 22 20:08:15 SNTP Synchronised again to server: 212.159.6.9
<102> Aug 22 21:07:54 SNTP Synchronised to server: 212.159.13.49
<102> Aug 22 22:07:54 SNTP Synchronised to server: 212.159.6.9
<102> Aug 22 23:07:54 SNTP Synchronised again to server: 212.159.6.9
<4> Jan  1 00:00:14 KERNEL Warm restart
<82> Jan  1 00:00:26 UPnP framework disabled
<82> Jan  1 00:00:28 UPnP framework disabled
<82> Jan  1 00:00:30 UPnP framework disabled
<85> Jan  1 00:00:36 FIREWALL event (1 of 1): created rules
<85> Jan  1 00:00:36 FIREWALL event (1 of 1): modified rules
<82> Jan  1 00:00:36 UPnP framework enabled
<85> Jan  1 00:00:38 FIREWALL level changed to Standard.
<85> Jan  1 00:00:38 FIREWALL event (1 of 1): deleted rules
<148> Jan  1 00:00:38 DHCS server up
<173> Jan  1 00:00:47 xDSL linestate down
<3> Jan  1 00:01:05 [ANTI_SPOOFD] (err) llist_getobject_at for ENV.ANTI_SPOOFD's value failed
<173> Jan  1 00:01:17 xDSL linestate down
<173> Jan  1 00:01:43 xDSL linestate up (ITU-T G.992.5; downstream: 12959 kbit/s, upstream: 1215 kbit/s; output Power Down: 20.9 dBm, Up: 12.3 dBm; line Attenuation Down: 22.5 dB, Up: 10.8 dB; snr Margin Down: 6.1 dB, Up: 6.4 dB)
<39> Jan  1 00:01:58 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:02:05 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:02:18 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:02:49 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:03:02 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:03:32 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:03:46 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:04:15 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:04:29 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:04:45 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:04:58 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:05:14 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:05:28 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:05:42 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:05:55 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<100> Jan  1 00:06:35 SNTP Unable to contact server: 198.18.1.9
<39> Jan  1 00:07:12 PPP CHAP Receive challenge (rhost = JUNOS)
<39> Jan  1 00:07:16 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Jan  1 00:07:23 PPP CHAP Chap receive success : authentication ok
<39> Jan  1 00:08:04 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:08:08 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:08:21 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:08:51 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:09:05 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:09:20 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:09:33 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<39> Jan  1 00:10:54 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:10:54 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:11:08 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:11:39 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:11:52 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:11:59 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:12:12 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<100> Jan  1 00:12:20 SNTP Unable to contact server: 198.18.1.9
<35> Jan  1 00:12:31 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:12:44 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:12:47 PPP CHAP authentication failed (Internet)
<100> Jan  1 00:18:05 SNTP Unable to contact server: 198.18.1.9
<39> Jan  1 00:18:21 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:18:51 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:19:05 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:19:36 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:19:49 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:20:19 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:20:32 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<35> Jan  1 00:21:02 PPP CHAP authentication failed (Internet)
<39> Jan  1 00:21:16 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<38> Jan  1 00:21:23 PPP CHAP Chap receive success : authentication ok
<132> Jan  1 00:21:23 PPP link up (Internet) [172.16.42.141]
<85> Jan  1 00:21:23 FIREWALL event (1 of 6): deleted rules
<132> Jan  1 00:31:23 PPP link down (Internet) [172.16.42.141]
<85> Jan  1 00:31:24 FIREWALL event (1 of 26): created rules
<85> Jan  1 00:31:24 FIREWALL event (1 of 16): modified rules
<39> Jan  1 00:31:37 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<38> Jan  1 00:31:40 PPP CHAP Chap receive success : authentication ok
<132> Jan  1 00:31:40 PPP link up (Internet) [172.16.42.151]
<85> Jan  1 00:31:41 FIREWALL event (1 of 1): deleted rules
<132> Jan  1 00:41:40 PPP link down (Internet) [172.16.42.151]
<85> Jan  1 00:41:41 FIREWALL event (1 of 1): created rules
<85> Jan  1 00:41:41 FIREWALL event (1 of 1): modified rules
<39> Jan  1 00:41:54 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<38> Jan  1 00:41:57 PPP CHAP Chap receive success : authentication ok
<132> Jan  1 00:41:57 PPP link up (Internet) [172.16.42.210]
<85> Jan  1 00:41:58 FIREWALL event (1 of 1): deleted rules
<132> Jan  1 00:51:58 PPP link down (Internet) [172.16.42.210]
<85> Jan  1 00:51:58 FIREWALL event (1 of 1): created rules
<85> Jan  1 00:51:58 FIREWALL event (1 of 1): modified rules
<39> Jan  1 00:52:11 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<39> Jan  1 00:52:48 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Jan  1 00:52:54 PPP CHAP Chap receive success : authentication ok
<132> Jan  1 00:53:23 PPP link up (Internet) [80.189.97.52]
<85> Jan  1 00:53:24 FIREWALL event (1 of 1): deleted rules
<99> Aug 22 23:10:20 SNTP Systemtime update: time setting 00:55:05 > new time setting: 23:10:20
<102> Aug 22 23:10:20 SNTP Synchronised to server: 212.159.13.49
<102> Aug 23 01:09:59 SNTP Synchronised to server: 212.159.6.10
<14> Aug 23 01:45:15 CONFIGURATION saved by TR69
<81> Aug 23 01:54:13 FIREWALL replay check (1 of 1): Protocol: ICMP  Src ip: 192.168.1.69 Dst ip: 173.194.66.188 Type: Destination Unreachable Code: Host Unreacheable
<102> Aug 23 02:09:59 SNTP Synchronised to server: 212.159.13.49
<102> Aug 23 03:09:59 SNTP Synchronised again to server: 212.159.13.49
<102> Aug 23 04:09:59 SNTP Synchronised again to server: 212.159.13.49
<81> Aug 23 04:49:02 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 207.30.135.165 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 04:52:22 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 181.236.121.173 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 23 05:09:59 SNTP Synchronised again to server: 212.159.13.49
<84> Aug 23 05:43:06 IDS proto parser : tcp null port (1 of 1) : 113.108.21.16   80.189.97.52    0040 TCP 12208->0 [S.....] seq 917219304 win 8192
<102> Aug 23 06:09:59 SNTP Synchronised again to server: 212.159.13.49
<81> Aug 23 06:14:15 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 81.133.112.171 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 06:31:36 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 217.15.151.250 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<37> Aug 23 07:04:11 LOGIN User logged in on [HTTP] (from 192.168.1.  )
<37> Aug 23 07:04:21 LOGIN User logged in on TELNET (192.168.1.  )
<37> Aug 23 07:04:39 LOGOUT User logged out on TELNET (192.168.1.  )
<102> Aug 23 07:09:59 SNTP Synchronised to server: 212.159.6.9
<37> Aug 23 07:11:14 LOGIN User logged in on TELNET (192.168.1.  )
<81> Aug 23 07:21:55 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 200.6.144.24 Dst ip: 80.189.97.52 Type: Time Exceeded Code: Time to Live exceeded in Transit
<81> Aug 23 07:44:48 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 120.151.95.68 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Communication Administratively Prohibited
<37> Aug 23 08:08:06 LOGIN User logged in on [HTTP] (from 192.168.1.  )
<102> Aug 23 08:09:59 SNTP Synchronised to server: 212.159.13.49
<81> Aug 23 08:11:57 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 124.168.180.182 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<37> Aug 23 08:12:39 LOGOUT User logged out on TELNET (192.168.1.  )
<37> Aug 23 08:18:41 LOGIN User logged in on TELNET (192.168.1.  )
<37> Aug 23 08:19:23 LOGIN User logged in on [HTTP] (from 192.168.1.  )
<81> Aug 23 08:54:45 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 101.84.86.35 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 09:03:47 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 121.13.176.182 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 23 09:09:59 SNTP Synchronised again to server: 212.159.13.49
<81> Aug 23 09:45:59 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 121.237.173.111 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 23 10:09:59 SNTP Synchronised to server: 212.159.6.9
<81> Aug 23 10:26:55 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 219.237.16.18 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<37> Aug 23 10:28:51 LOGIN User logged in on [HTTP] (from 192.168.1.  )
<102> Aug 23 11:09:59 SNTP Synchronised to server: 212.159.13.49
<81> Aug 23 11:23:11 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 37.126.8.148 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 11:25:35 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 119.179.76.137 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<37> Aug 23 11:38:42 LOGIN User logged in on [HTTP] (from 192.168.1.  )
<81> Aug 23 11:58:44 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 60.186.11.180 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 23 12:09:59 SNTP Synchronised to server: 212.159.6.9
<81> Aug 23 12:34:38 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 115.62.126.252 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 23 13:09:38 SNTP Synchronised to server: 212.159.6.10
<81> Aug 23 13:10:32 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 96.254.99.43 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 13:51:29 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 123.65.247.176 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 23 14:09:38 SNTP Synchronised to server: 212.159.6.9
<81> Aug 23 14:27:19 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 182.86.244.124 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 23 15:09:38 SNTP Synchronised to server: 212.159.13.49
<81> Aug 23 15:14:11 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 192.99.138.53 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 15:27:24 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 59.172.139.113 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 15:52:26 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 198.27.81.79 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 15:55:15 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 98.112.221.81 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 16:05:54 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 183.11.156.196 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<84> Aug 23 16:06:10 IDS proto parser : tcp null port (1 of 1) : 123.151.42.61   80.189.97.52    0040 TCP 12201->0 [S.....] seq 1359433403 win 8192
<81> Aug 23 16:07:06 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 146.0.78.118 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 23 16:09:38 SNTP Synchronised again to server: 212.159.13.49
<84> Aug 23 16:13:04 IDS scan parser : tcp port scan: 17.173.66.103 scanned at least 10 ports at 80.189.97.52.  (1 of 1) : 17.173.66.103   80.189.97.52    0040 TCP 443->55102 [...R..] seq 3601137515 win 8201
<81> Aug 23 16:13:23 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 191.201.34.76 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 16:47:34 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 200.150.80.196 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 23 17:06:42 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 199.87.85.242 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 23 17:09:38 SNTP Synchronised to server: 212.159.6.9
<81> Aug 23 17:23:23 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 163.179.244.154 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 17:29:29 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 75.129.104.48 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Communication Administratively Prohibited
<81> Aug 23 17:38:07 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 179.100.90.131 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 17:49:11 FIREWALL replay check (1 of 1): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 23 18:09:38 SNTP Synchronised again to server: 212.159.6.9
<81> Aug 23 18:12:01 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 211.236.136.220 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 18:45:29 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 23 19:06:12 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 202.1.205.34 Dst ip: 80.189.97.52 Type: Time Exceeded Code: Time to Live exceeded in Transit
<81> Aug 23 19:06:30 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<102> Aug 23 19:09:38 SNTP Synchronised again to server: 212.159.6.9
<81> Aug 23 19:09:39 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 116.224.140.62 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 19:27:04 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<84> Aug 23 19:37:34 IDS proto parser : tcp null port (1 of 1) : 113.108.21.16   80.189.97.52    0040 TCP 12206->0 [S.....] seq 560926669 win 8192
<81> Aug 23 19:44:45 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 23 19:48:53 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 124.167.183.176 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 23 19:51:00 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 23 20:04:19 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 71.118.252.66 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 23 20:09:38 SNTP Synchronised to server: 212.159.13.50
<81> Aug 23 20:23:50 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 23 20:44:29 FIREWALL replay check (1 of 1): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<102> Aug 23 21:09:38 SNTP Synchronised to server: 212.159.6.9
<81> Aug 23 21:16:32 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 23 21:37:10 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 23 22:08:06 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<102> Aug 23 22:09:38 SNTP Synchronised again to server: 212.159.6.9
<81> Aug 23 22:28:44 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 23 22:39:07 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 23 22:49:29 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<37> Aug 23 22:57:41 LOGIN User logged in on [HTTP] (from 192.168.1.  )
<102> Aug 23 23:09:38 SNTP Synchronised to server: 212.159.13.49
<81> Aug 23 23:33:39 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 23 23:43:59 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<102> Aug 24 00:09:38 SNTP Synchronised to server: 212.159.6.9
<81> Aug 24 00:27:25 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 00:41:59 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 00:56:51 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 81.228.83.129 Dst ip: 80.189.97.52 Type: Time Exceeded Code: Time to Live exceeded in Transit
<81> Aug 24 01:02:22 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 01:07:22 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<102> Aug 24 01:09:38 SNTP Synchronised again to server: 212.159.6.9
<81> Aug 24 01:26:48 FIREWALL replay check (1 of 1): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 02:00:00 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 02:00:51 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 90.168.171.247 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Port Unreacheable
<102> Aug 24 02:09:38 SNTP Synchronised again to server: 212.159.6.9
<81> Aug 24 02:57:56 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 03:08:55 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 123.202.193.99 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Communication Administratively Prohibited
<102> Aug 24 03:09:17 SNTP Synchronised again to server: 212.159.6.9
<81> Aug 24 03:22:48 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.97.52 Type: Destination Unreachable Code: Host Unreacheable
<132> Aug 24 03:30:29 PPP link down (Internet) [80.189.97.52]
<85> Aug 24 03:30:30 FIREWALL event (1 of 1): created rules
<85> Aug 24 03:30:30 FIREWALL event (1 of 1): modified rules
<39> Aug 24 03:30:43 PPP CHAP Receive challenge (rhost = bras-red6.wv)
<39> Aug 24 03:30:43 PPP CHAP Receive challenge (rhost = JUNOS)
<38> Aug 24 03:30:53 PPP CHAP Chap receive success : authentication ok
<132> Aug 24 03:31:02 PPP link up (Internet) [80.189.146.243]
<85> Aug 24 03:31:02 FIREWALL event (1 of 1): deleted rules
<14> Aug 24 03:31:11 CONFIGURATION saved by TR69
<81> Aug 24 03:32:12 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 213.49.238.70 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 03:44:08 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 122.159.73.192 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 24 03:48:19 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Host Unreacheable
<102> Aug 24 04:09:17 SNTP Synchronised to server: 212.159.13.49
<81> Aug 24 04:19:51 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 04:40:52 FIREWALL replay check (1 of 1): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 05:07:25 FIREWALL replay check (1 of 3): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Host Unreacheable
<102> Aug 24 05:08:55 SNTP Synchronised to server: 212.159.6.9
<81> Aug 24 05:19:02 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 159.0.72.216 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 05:47:27 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 176.224.210.87 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 24 05:48:11 FIREWALL replay check (1 of 1): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 06:00:49 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Host Unreacheable
<102> Aug 24 06:08:55 SNTP Synchronised to server: 212.159.13.50
<81> Aug 24 06:35:37 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Host Unreacheable
<81> Aug 24 06:36:56 FIREWALL icmp check (1 of 1): Protocol: ICMP  Src ip: 123.8.255.45 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Port Unreacheable
<81> Aug 24 06:57:19 FIREWALL replay check (1 of 2): Protocol: ICMP  Src ip: 82.10.56.194 Dst ip: 80.189.146.243 Type: Destination Unreachable Code: Host Unreacheable
<102> Aug 24 07:08:55 SNTP Synchronised to server: 212.159.13.49
{admin}
Telnet recording will continue all day today as it is the 3rd day! I've heard nothing more from Plusnet about my non-existent test connector!
Fixes: 162
Morning Avodat,
There is a great deal going on in here which needs a lot of analysis... but that will need to wait until after prayers.
Kevin
Anotherone
Champion
Fixes: 21
Just so you have a better understanding, the "log" is logging/recording all the time. When you look at it through the GUI, you can only see the last "x" entries. When you Telnet (either directly or through Routerstats) you get "x"+ + (whatever the value is, never counted) entries. When the memory allocated to the log is full, it overwrites the oldest entries, which is why you can "lose" information.
Your login from 192.168.1.254 is not  a personal IP, so no needtoredact.What you ought to redact is your current public IP address, the one beginning  [80.189.xxx.xxx]  Just delete the last 2 sets of the ID. The earlier ones in the log prior to 03:30:31:02  [84.93.214.184], [80.189.81.160], etc are no longer relevant as they are long disconnected and can be left in.
I'll just post this first.
avodat
Anotherone - thanks. The logins I redacted were not the numbers you have shown - it was login numbers BY, not TO, that I deleted  Smiley
Townsman - I'll be back home about 1.30(ish). If it follows the 3 day pattern we should get an alert this afternood or, leas likely, this evening.
Enjoy your morning, whatever it may contain, both of you.
Bye for now
Anotherone
Champion
Fixes: 21
Whichever you deleted was not especially relevant anyway, just the ones I have mentioned and your username.
Although I suppose leaving out the last digit of the 192.168.1.xx  hides your internal IP address and might give a little further security.
It's the current Public IP address that is more important.
Anotherone
Champion
Fixes: 21
Just a brief comment at this point. Only one event of interest as of yet in the log since you started RouterStats. A few things before that, will comment on shortly.
Edit: to correct above statement
Anotherone
Champion
Fixes: 21
avodat, some current stats when you can would be a useful update.
Also a Routerstats Downstream SNRM graph that covers 0330 last night.
Fixes: 162
Avodat,
We are both presently working our way through this log - there is a lot going on here - we have not forgotten you!
Kevin
Fixes: 162
Hi Avodat,
Can you please look here - http://192.168.1.254/cgi/b/cfg/ov/?be=0&l0=1&l1=1 - it will prompt you to login to your router.
Can you advise what is the summer time setting please.
Time Configuration
Time Source: Automatic
Date: 24-08-2014
Time: 19:01:26
Timezone: (UTC)
Summer Time: Yes
Time Since Power-on: 40 days, 3:39:25
Time Server 1: ntp.plus.net
We think we have a theory on the strange time stamps, but need to check your settings.
Kevin
