Super random connection speeds
- Re: Super random connection speeds
04-06-2009 8:06 AM
Quote We've got loads of extensions, i can count 8 off the top of my head
Why ?. Can you imagine all that wiring, sockets next to mains wiring I guess, all that possibility of noise pickup!!!.
No wonder it's so different when all that wiring is disconnected.
I think you need to review what sockets you actually need and to see if the others can be disconnected easily.
Finding out how the wiring is arranged is perhaps the first task?
04-06-2009 8:14 AM
04-06-2009 8:40 AM
Using the master socket (not the test socket) could you do a check please. Go round the house and make sure there is absolutely nothing plugged in to any telephone socket (not even a filter). Now just check the router stats (a speed test will tell us nothing). Are the stats similar to when you were in the test socket or the worse statistics you got before unplugging everything?
If the answer is close to the test results it means that either one of you filters or something you have plugged in is causing the problem. By plugging things in one at a time and checking the stats after each (you need to look for a significant drop in noise margin and/or sync speed) you should be able to identify what it is.
If unplugging everything hasn't improved the results it is definitely the wiring.
04-06-2009 10:06 AM
Quote from: MisterW
I've not idea why - its not actually our house (rented) so i'm a bit nervous of going about fiddling with the wiring.
In theory the only extension we need is in the master bedroom as that's the only location in the house where there is decent wireless reception for all the rooms - there isnt really a need for the others. Looks like i could be leaving it in the test socket for the forseeable future!
Jelv - Will so that when i get home tonight. I've tried it before to aid stability (and was asked to do it by PN support) but dont remember it making a difference. Will certainly try though!
04-06-2009 10:19 AM
04-06-2009 10:29 AM
jim:quote
04-06-2009 10:45 AM
Quote 've not idea why - its not actually our house (rented) so i'm a bit nervous of going about fiddling with the wiring
Ah, sorry didnt realise it was rented, as you say not a good idea to be fiddling with wiring.
Quote Is there any salt in using a wireless range extender,
Stick with the Cat5 as Jelv suggested , wireless extenders will increase latency and reduce throughput.
If the Cat5 is obtrusive you might consider a HomePlug networking over the mains solution.
04-06-2009 11:59 AM
As you rent out a room in the telephone exchange (please note guys), (never mind the house), this should be relatively easy to resolve without going to the expense of Cat5e Cable and AP's, Homeplugs or whatever.
As has already been suggested, what is plugged in where and finding out how the wiring is arranged is the first task and I cannot stress enought that everything must be done in a methodical manner, only one change at a time, otherwise you could go round in circles.
Sky has been mentioned, if you have sky or any similar boxes they MUST be plugged in through a filter, don't be fooled by what is on the end of a sky lead - it's NOT a filter. With the wiring itself, as long as you don't go round cutting anything, you won't do any permanent damage or anything that is not undo-able.
Has your connection dropped at all since you've been plugged into the test socket? I suggest that whilst you are connected to the test socket, you go round first and check that every other socket is dead and absolutely nothing is plugged in either. Then take a set of Router Line Stats, then replace the faceplate and plug into the master and the immediately take a new set of stats. Are they significantly different ie noticeably lower syncspeed or noise margin? If they are, as jelv has already said it will be a wiring problem.
Then do as jelv has suggested, go round and plug one item at a time in (and have only one plugged in at once) and look for any change in Noise Margin or Sync immediately after plugging an item in.
Post back the results at this point, in case there is anything obvious to comment on.
04-06-2009 12:34 PM
Quote from: AdamR That's current set-up, minus the AP. Is there any salt in using a wireless range extender, as opposed to an AP or will that just increase latency?
The point of using a WAP connected via a ethernet cable is that it won't affect performance. Every time you go across a wireless link you will affect performance (particularly latency) and increase the chance of errors. If you are in to gaming or anything else where latency is important the order of preference would be wired, then homeplug and a long way last wireless. (For example I do consultancy for two different people using different VPN software which can't co-exist on the same PC, I therefore have one of them on my wife's PC upstairs. I currently have a Cat 5e cable trailed up the stairs because using wireless the VPN kept dropping out).
If you need wired connections upstairs I would suggest:
-----Downstairs------------ -----------Upstairs-----------------
Master---Router+----------------------------Switch+------- WAP-+-Wireless PCs
Socket +---Wired PC 1 +------- Wired PC 2
+ Wireless PCs +--------Wired PC 3
The switch is a standard ethernet switch which you can get for around £5
With this arrangement your router would be providing wireless networking in one part of the house and the WAP for the rest (make sure they are on different channels!). You should be able to optimise the position of the router and WAP to give good coverage all over the house.
DHCP (if you don't have static IPs set) should be only enabled on the router.
04-06-2009 1:26 PM
04-06-2009 1:37 PM
04-06-2009 2:04 PM
04-06-2009 2:10 PM
My suggestions are totally risk free and he can take it all with him when he moves out and reuse or sell the equipment if he no longer needs it.
04-06-2009 2:46 PM
I will test the wiring i.e. check stats in test and master socket with everything unplugged, and if there is no difference i'll move on to checking individual pieces of equipment/filters. If it does turn out to be a wiring fault i'll just leave the router plugged in to the test socket and figure out a way to boost the wireless signal, be it by WAP or just sitting on my stairs when i use the net!
Oddly enough there are network points throughout the house but all the cabling runs to a cupboard upstairs and just stops - it's not even terminated.
I think the house was a rushed job!
04-06-2009 11:12 PM
Link Information
Uptime: 1 day, 2:54:58
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,520
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 3.00
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 11.5 / 22.0
SN Margin (Up/Down) [dB]: 22.0 / 12.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 1 / 1,351
CRC Errors (Up/Down): 1 / 1
HEC Errors (Up/Down): 0 / 1
In master with everything unplugged:
0 days, 0:00:09
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,000
Line Attenuation (Up/Down) [dB]: 11.5 / 25.0
SN Margin (Up/Down) [dB]: 16.0 / 12.0
Loss of Framing (Local/Remote): 2 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Wiring issue then?
