Speed near Burrowbridge Somerset
- Re: Speed near Burrowbridge Somerset
- « Previous
- 1
- 2
- Next »
31-03-2014 5:34 PM
Thank you Yes as long as it will be no worse
Message 16 of 19
(239 Views)
02-04-2014 9:20 AM
Unfortunately it has all failed again
Results Image not loaded
1. Best Effort Test:
Download Speed
0.25 Mbps
0 Mbps 0.25 Mbps
Max Achievable Speed
Download speed0.25 Mbps
For your connection, the acceptable range of speeds0.05 Mbps-0.25 Mbps.
Additional Information:
Your DSL Connection Rate :0.29 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.25 Mbps
Download Speed
0.25 Mbps
0 Mbps 0.25 Mbps
Message 17 of 19
(239 Views)
03-04-2014 9:38 AM
I've placed a SNR reset on your line which has now lifted your profile to 1.5Mb/s, let us now if that helps.
Message 18 of 19
(239 Views)
03-04-2014 2:22 PM
1. Best Effort Test: -provides background information.
Download Speed
1.47 Mbps
0 Mbps 2 Mbps
Download speedachieved during the test was - 1.47 Mbps
Yes that is fine but hope it will be sustainable as 1.89 is the most ever Connection Rate Will check again later Thank you
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Your DSL Connection Rate :1.89 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 1.5 Mbps
If you wish to discuss these results please contact your Broadband Service Provider.
If you are experiencing problems with specific applications, servers or websites please contact your Broadband Service Provider for assistance.
Your test has completed please close this window to exit the performance tester.
Download Speed
1.47 Mbps
0 Mbps 2 Mbps
Message 19 of 19
(239 Views)
- « Previous
- 1
- 2
- Next »
