Static IP
lisapetewright
Static IP
Thinking of taking this as an add on
Is it an instant add on?
Is that £5 PCM or £5 for the contract (website doesn't say)
Getting fed up using DNS exit to redirect my IP to my Pi so this is an option to keep it on 24/7
Finguz
Re: Static IP
Just one payment of £5, and it should be instant  Smiley
darklight
Re: Static IP
once you pay your one off payment of £5 you get your static ip, but you need to reboot your router or drop your session and reconnect the session to get it.
lisapetewright
Re: Static IP
Really.... whoop done
Cool beans I can do all that from here at home
lisapetewright
Re: Static IP
Thanks guys. All done, rebooted my Asus RT-N66U and working perfectly.
Updated my DNSExit account to a static IP, entered IP done. Pi is working over the IP address and www address.
Re: Static IP
You might want to request a different rDNS because currently it will be your username by default - you can request the change here https://www.plus.net/wizard/index.html?p=wizard&page=22425&wizard_id=38
BRABUS
Re: Static IP
I just read that link, I am going to find some paracetamol now  Cheesy
lisapetewright
Re: Static IP
Quote from: AndyH
Not sure what you mean or why?
Re: Static IP
Because it will protect your PN user name.....I think! Undecided
lisapetewright
Re: Static IP
Umm the link doesnt really explaine it at all, might have to call Plusnet
dick:quote
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Static IP
What are you unsure of?
We can set your rDNS so it uses your Static IP?
I, personally, aren't too bothered that it uses my username.
Chris Pettitt
Cloud Environments Engineer
lisapetewright
Re: Static IP
Chris, can you set it to what ever is the safest option going. I have no idea about any of it at all as it's not clear for them that don't know.
dick:quote
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Static IP
I'll set it to IP.plus.com rather than username.plus.com
 Chris Parr
 Plusnet Staff
lisapetewright
Re: Static IP
Thanks Chris, do i need to reboot or anything my end?
dick:quote
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Static IP
Nope, I've done that now and it'll take around 24 hours to update. Nothing you need to do Smiley
 Chris Parr
 Plusnet Staff
