Speed near Burrowbridge Somerset
stathe
Results Image not loaded
1. Best Effort Test: -provides background information.
Download  Speed
0.71 Mbps
0 Mbps 2 Mbps
Max Achievable Speed
Download speed achieved during the test was - 0.71 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Additional Information:
Your DSL Connection Rate :1.44 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 1.25 Mbps
My speed seems stuck at .71 despite having been at 1 + for some time  I would have expected it to be nearer the profile,
Despite floods all around I have found it acceptable for some time  now that  the weather improved and water has declined My speed has gone . Or would this be because I have altered my phone line to Plusnet and unlimited ?  Thank You
Re: Speed near Burrowbridge Somerset
What's your Current Line Speed from the Member Centre?
stathe
Telephone number:
<snip>
Phone exchange:
    BURROWBRIDGE
Estimated line speed:
    1.0Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-12-23 17:59:39
Current line speed:
    0.75 Mb
This is as in my recent BT test as  posted here
jim:green phone number removed mod:end
Fixes: 62
Current line speed is stuck and needs increasing to 1.2Mbps
The Current Line Speed does not match the BT IP Profile from the speed test.
It should catch up automatically, but if it doesn't, one of the DCT should be able to give it a nudge for you.
stathe
Thank You I have filled in a fault for it so will see what goes
stathe
D C T    Huh?Huh
Digital Care Team - the Plusnet staff who man (and woman) these forums.  Cool
stathe
Well it hardly works at all now  AWFUL
stathe
Download  Speed
0.18 Mbps
0 Mbps 2 Mbps
Download speed0.18 Mbps
For your connection, the acceptable range of speeds0.4 Mbps-2 Mbps.
Your DSL Connection Rate :1.54 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
Hardly working  now and have been sent some talk of wireless routers
stathe
Download  Speed
0.2 Mbps
0 Mbps 2 Mbps
Download speedachieved during the test was - 0.2 Mbps
Your DSL Connection Rate :1.57 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
This is similar to last week-end it barely works ,to-day but was acceptable during the week why ?Huh
SpendLessTime
Aspiring Hero
Fixes: 60
You need to ensure that you keep updating your support ticket as well as posting here. Just keep at Plusnet for an answer and good luck. I'm 4 months into my speed issues!
Has your speed improved at all?
stathe
Yes thank you, after a 1 hour wait on Saturday night ,I have acceptable speed in as far as the i player now just about works.  I would like it a bit faster if possible
Download  Speed
0.96 Mbps
0 Mbps 1 Mbps
Download speedachieved during the test was - 0.96 Mbps
For your connection, the acceptable range of speeds is 0.2 Mbps-1 Mbps.
Your DSL Connection Rate :1.38 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 1 Mbps
If you wish to discuss these results please contact your Broadband Service Provider.
If you are experiencing problems with specific applications, servers or websites please contact your Broadband Service Provider for assistance.
Your test has completed please close this window to exit the performance tester.
Please visit the FAQ if you are unable to understand the test results.
We can try a SNR reset on your line that would hopefully give you a bit of a faster connection, it's worth a try if you;re happy for me to do it?
