Speed Ok ish but everything has slowed down
Legend
Fixes: 293
Re: Speed Ok ish but everything has slowed down
Thanks for those, Linda - they are strongly suggesting a fault. Would be interesting and informative to see the Hub data and results of phone-line test, too.
destiny234
John,
The quiet line test was ok,
I can`t find this on the home screen `
For the Hub Two -
Linda
Legend
Fixes: 293
Glad the phone is OK - one less avenue of possible issues, Does the picture below help you find the required page?
destiny234
John,
I have searched and searched and can`t find that page on my plusnet
Linda
Legend
Fixes: 293
Linda - it is on your router.
Fixes: 95
@destiny234
Use this link http://192.168.1.254
From Home page bottom right >Advanced settings; Middle left >Technical log; you'll need the admin password from the card
destiny234
Legend
Fixes: 293
Thanks for that Linda. It is good to find someone who asks for help and then helps us to help them. From that last bit of info, I'm 99% confident there is a fault on the OpenReach network, so suggest you initially report it via https://www.plus.net/help/report-a-problem/
If it comes back and says there isn't a fault, let us know and further advice can be given, but I'm confident it will suggest getting OR out.
destiny234
John/ Dan
Thank you for your patience, turns out I knew very little lol.
I will report it right now.
Cheers
Linda
Fixes: 64
@destiny234
Not that this helps with the immediate problem but have you checked recently to see if there are any OR plans for your area. Put your post code in www.openreach.com
Given you speeds and the fact the Scottish government is spending public money of superfast broadband you might be in their plans.
destiny234
Thanks Brian I’ll ask them.
The last time open reach were here the guy advised me to try EE. I’m still in contract with Plusnet for 9 months but to be honest I’m so fed up I’d be happy to pay to get out
linda
Legend
Fixes: 293
Linda - don't listen to 'suggestions' like that. The fault you have would follow you to EE.
destiny234
John, I did wonder , thanks for confirming though
Linda
Fixes: 64
@destiny234
Given your speeds, changing ISP probably wouldn't make a difference.
OR engineers may not know OR plans - see if the website says anything.
destiny234
Well I was on the phone to bt and he did something to the router. There had apparently been an outage locally a couple of days ago and it can take a while to adjust at the router. Amazingly it seems ok! I haven`t tried netflix yet, that is the true test.
I will let you know how it goes during the next few days.
Meanwhile thank you everybody 🙂
Linda
