Banding removal
zpeterk
Banding removal
Hi
Could the banding on my line be lifted, I have been synced for 80 days without a disconnect.
Many residents in my area have come off VDSL as fibre is now available so there should be less crosstalk than there was.
8 REPLIES 8
Fixes: 480
Re: Banding removal
@zpeterk
How do you know that your line is banded? The automatic DLM should automatically adjust for any change in cross talk.
What SNR is your hub reporting?
zpeterk
Re: Banding removal
Fixes: 480
Re: Banding removal
@zpeterk
So downstream  tops out at 55 Mbps. Do you by any chance have a static IP address?
zpeterk
Re: Banding removal
I have a static IP
Fixes: 480
Re: Banding removal
Hopefully a member of the help team will pick this up soon as it could be an Openreach banding issue or a Plusnet setting that’s exclusive to those with a static IP address.
Fixes: 117
Re: Banding removal
@zpeterk
If FTTP is available have you considered moving to it. Speeds should be close to the package you choose. I'm on FF74 and consistenly get above 70 down.
zpeterk
Re: Banding removal
The fttp is an altnet and I have 14 months left on my contract.
Fixes: 117
Re: Banding removal
@zpeterk
Fair enough. Without swallowing early termination charges your'e stuck with PN until near the end of your contract or OpenReach put in an appearance to install FTTP.
