Query about "view my usage"
- Re: Query about "view my usage"
- « Previous
- 1
- 2
- Next »
29-01-2008 8:53 AM
yep ! it is wep
Message 16 of 24
(445 Views)
29-01-2008 8:59 AM
I talking about JMD not you Shutter
Message 17 of 24
(445 Views)
29-01-2008 9:09 AM
Sorry, your reply came immediately after my post...
Message 18 of 24
(445 Views)
29-01-2008 1:38 PM
Yes my wi-fi router is security protected [wpa] pierre-pierre.
Mand - the freetime usage varies from 96.17kb to 66.42kb
Message 19 of 24
(445 Views)
29-01-2008 1:50 PM
@jmd
That level of usage overnight is just normal internet "noise" and nothing to worry about. You could try turning on the PlusNet firewall (if you haven't already) which should cut this down.
My overnight usage is in the region of 160kb.
To put things in perspective, 1000kbytes = 1Mbyte, 1000Mbytes = 1Gbyte
so, at 70kbytes/day usage you'd take 14,285days to use 1Gbyte (which is the amount of allowance for a month in PN's cheapest package!)
(I think I've done the arithmetic correctly - someone will correct me if it's wrong)
Edit: typos
Edit: typos
Message 20 of 24
(445 Views)
29-01-2008 1:54 PM
Arithmetic is fine. But:
14,286 if you round up to the nearest number
70KB per day is a really small amount.
Message 21 of 24
(445 Views)
29-01-2008 1:59 PM
Thanks for information - it is just that it seemed a lot higher than it has been in previous months.
My broadband firewall is switched on.
But there is still the conflict over whether to unplug/switch off router or leave it on that some people seem to have have. Oh well..........
Message 22 of 24
(445 Views)
29-01-2008 3:30 PM
Quote from: jmd it is just that it seemed a lot higher than it has been in previous months
It varies from day to day and from month to month - it's just dependent on how many nefarious sorts are doing port scans and the like.
As for whether to leave it on or to turn it off... I'd say it's down to preference - no hard and fast rule. I leave mine on and have never had a problem.
I think that the only thing that you definitely shouldn't do is turn it off and on repeatedly over a short time span of, say, a couple of hours.
Message 23 of 24
(445 Views)
29-01-2008 7:39 PM
Many thanks to all who have replied and helped with my question regarding whether a router should be left switched on or not. Things are very much clearer now!
I'll do some tests and see whether my connection is a "Leave the router on, or else I'll get speed variations" or an "It's OK to switch it off" one.
Cheers
Keith
Cheers
Keith
Message 24 of 24
(445 Views)
- « Previous
- 1
- 2
- Next »
