Problems with IPlayer & Unlimited & Value
- Re: Problems with IPlayer & Unlimited & Value
- « Previous
- Next »
08-07-2009 8:55 AM
so thought the best help i could give was to point to that limited old info in case no other packet ninja picked up the testing
08-07-2009 10:13 AM
cleared dns cache ect and tried firefox an still 0x80
added a capture to this ticket incase you wanted to have look. ID: 28968961
08-07-2009 10:24 AM
Plusnet Technology
08-07-2009 11:04 AM
Thanks! Looks like it wasn't the simplest of problems to sort out!
09-07-2009 9:51 PM
its all gone pete tong, getting 0x60 again.
added pcap to this ticket ID: 28968961
EDIT
just flushed dns an cleared browser and flashplayer history out with ccleaner and tried the stream in FF and get 0x80 added that pcap to same ticket
09-07-2009 10:15 PM
10-07-2009 9:26 AM
10-07-2009 9:45 AM
Plusnet Technology
10-07-2009 10:05 AM
em cant remember what i did in the 5 or so mins b4 but the things i was doing yestrday was spotify(on all day) irc using Mirc (on all day) messenger (on all day) i did fire up limewire 5.1.3 for a few minutes but am sure that was after i got the 0x60 but could of been b4 not sure also peer gurdian 2 got switched on around this time for abit.
rest was just cruzien the web.
it was only that one instance so far i was streaming a prog late last nite and that was picked up fine and also there being picked up fine right now.
10-07-2009 10:08 AM
10-07-2009 10:13 AM
p.s if some of sigs in todays batch was for messenger cams then it seems to have worked to some degree as am now gettin 0x80 on sum ports but still getting 0x40 on other ports in the same capture on the same ip
same ip's source port 50167 dest 9049 0x60 and source port 49171 dest 9049 0x80
10-07-2009 11:30 AM
Plusnet Technology
17-07-2009 11:34 PM
27-07-2009 10:23 PM
- « Previous
- Next »
